RV.Net Open Roads Forum: Class C Motorhomes: THOR Quantum switch above sink
 > THOR Quantum switch above sink
alaina0817
Hammond,La.
Posted: 12/23/18 09:37am Link  |  Quote  |  Print  |  Notify Moderator
Hi Fellow Campers,
I have recently purchased a 22ft Thor Quantum camper.Read all my books and havent veen anle to figure out one of the 2 switches above kitchen sink.1 is for lights above sink and stove.One switch next to it,when turned on,cant find watch it does,even walked around outside.A yone out there knows what it does?
Thanks
Cindy B.
Dennis12
Ridgeley WV
Posted: 12/23/18 09:44am Link  |  Quote  |  Print  |  Notify Moderator
Do you hear a click ? could be your master shut off ???
Dennis Hoppert
bobndot
Posted: 12/23/18 10:01am Link  |  Quote  |  Print  |  Notify Moderator
Does your unit have an electric element in the water heater ?
If so, how to you activate it ?
alaina0817
Hammond,La.
Posted: 12/23/18 10:42am Link  |  Quote  |  Print  |  Notify Moderator
Master shut off is at steps,and also no sound of click
alaina0817
Hammond,La.
Posted: 12/23/18 10:43am Link  |  Quote  |  Print  |  Notify Moderator
Electric hot water is on demand,to activate switch in bath room
DrewE
Vermont
Posted: 12/23/18 11:20am Link  |  Quote  |  Print  |  Notify Moderator
Water pump control possibly? Exhaust fan for the range hood (though usually that would be noisy enough to leave no doubt as to what it does)?
bobndot
Posted: 12/23/18 01:54pm Link  |  Quote  |  Print  |  Notify Moderator
Does your unit have an automatic entrance light that illuminates when you open the door ? If so , it can be turned on/off .
This is a brand new unit correct ?
ron.dittmer
North-East Illinois
Posted: 12/23/18 02:13pm Link  |  Quote  |  Print  |  Notify Moderator
Hi Cindy,
The switch might turn on your Gray & Black Waste Tank Heaters. If that is the case, you want to make sure the switch is off until needed. Accidentally left on, your house battery will drain much more quickly leaving you wondering why.
The switch might also control your electric step. With the switch in one position, the step extends when the door is opened, and retracts when the door is closed. With the the switch in the other position, the step extends when the door is opened, but stays extended after shutting the door. The step should automatically retract when starting the main chassis engine to prevent driving away with the step extended.
Merry Christmas!
Ron Dittmer
2007 Phoenix Cruiser model 2350, with 2006 Jeep Liberty in-tow
bobndot
Posted: 12/23/18 07:49pm Link  |  Quote  |  Print  |  Notify Moderator
I agree with Ron, Thor website describes their Arctic Package as having heat strips on the holding tanks. If you have that option, a switch would be needed to operate them.
On a motorhome the heated pads are usually 120v models, thermostatically operating from 45F to 68F. If you plug into shore power or fire up the generator, that switch might illuminate with some kind of indicator LED to show you that it's on unless its hot where you are, then it might not illuminate due to the thermostat settings which are automatically factory set.
* This post was edited 12/23/18 09:26pm by bobndot *
ron.dittmer
North-East Illinois
Posted: 12/23/18 09:51pm Link  |  Quote  |  Print  |  Notify Moderator
Our waste tanks have 12V heating pads stuck to their under-sides. They resemble the kind used for heated seats though I am sure they are RV-specific. Then there is a layer of thin insulation covering over the entire tank with pad.
Here is a picture of our insulated waste tanks, center and left positions.
