RV.Net Open Roads Forum: Class A Motorhomes: Air Leak UPDATE FIXED!
 > Air Leak UPDATE FIXED!
Page of 5
Executive
Posted: 12/28/18 11:58am Link  |  Quote  |  Print  |  Notify Moderator
Hello all. I hope everyone had an enjoyable Christmas. Looking forward to the new year. To end this year, my coach decided to present me with a new problem. One that I need to fix ASAP. When the coach is idling, in drive, I am losing air pressure. Idling in gear at 5mph for a couple blocks and I will lose about 30psi. Driving at speed and the compressor keeps the air up but stopping at traffic lights and I can see the pressure begin to drop. I've blasted what fittings I have found and have located 5 small leaks which I will fix. The sixth is a pinhole in the front air tank so that will have to be replaced. None of these leaks are sufficient to cause the air pressure drop I'm experiencing. Further investigation revealed a possible culprit but I'm not sure how to proceed. With the coach idling, in gear, parking brake set, I can hear air escaping from the door air seal. I assume, (yeah, I know what that means) the air seal allows the psi to drop. What I don't know is how to trouble shoot it. So far, I've found no one that is familiar with how this seal works. I would guess there is a solenoid somewhere that controls it. Again, I assume it would have to be adjustable in order to control the psi to that seal but I could be wrong. I put a call into Monaco but I was 15th in cue so I left a voice mail and am waiting for them to call back. If anyone here who has had a similar problem and can point me in the right direction, that would be greatly appreciated. Thanks in advance....Dennis
* This post was last edited 01/10/19 09:35pm by Executive *   View edit history
A Simple Act of Caring Creates an Endless Ripple
Dennis and Debi Ten Years Full Timing
2014 Chevrolet Equinox LTZ W/ ReadyBrute
CLICK HERE TO VIEW OUR TRAVEL BLOG
ksg5000
Oregon
Posted: 12/28/18 01:31pm Link  |  Quote  |  Print  |  Notify Moderator
If the rig is parked/running can you open the door and apply soapy water to the door seal to spot a leak - kinda like finding a leak in an air mattress? Just a thought.
Kevin
mike brez
Unknown
Posted: 12/28/18 02:16pm Link  |  Quote  |  Print  |  Notify Moderator
Time to trade her in for a new one. [emoticon]
Sorry I have no clue but Merry Christmas to you and yours and happy New Year.
Hope it's a easy fix.
1998 36 foot Country Coach Magna #5499 Single slide
Gillig chassis with a series 40
02 Ford F250 7.3 with a few mods
2015 Wrangler JKU
Two Jayhawks
Lenexa Kansas
Posted: 12/28/18 03:01pm Link  |  Quote  |  Print  |  Notify Moderator
Sorry Dennis I can't comment on your question regarding the door seal. Are all your air springs passing the leak test?
Bill & Kelli
2015 DSDP 4366 pulling a 2014 Ford Edge
2002 Safari Zanzibar 3906 gone
1995 Fleetwood Bounder 36JD gone
Big Katuna
Deland, FL
Posted: 12/28/18 03:46pm Link  |  Quote  |  Print  |  Notify Moderator
Both my bigger air leaks were ride ht valves.
Maybe send Dou Rainer a PM?
My Kharma ran over my Dogma.
Kevarino
No Cal
Posted: 12/28/18 03:57pm Link  |  Quote  |  Print  |  Notify Moderator
I found this thread on another forum
air-door-seal
* This post was edited 12/28/18 04:12pm by Kevarino *
wildmanbaker
Kennewick, Washington
Posted: 12/28/18 04:55pm Link  |  Quote  |  Print  |  Notify Moderator
Dennis, you might try "Flex Seal" on the parts that are leaking. I know of someone that used it on a tire sidewall that had a leak you hear and feel, and it sealed it for at least a month.
Good luck
Wildmanbaker
vegasfoodguy
Reno Nv
Posted: 12/28/18 05:29pm Link  |  Quote  |  Print  |  Notify Moderator
Dennis, You may want to look into an ultrasonic leak detector. Find on Amazon or Ebay, makes finding the smallest leaks a piece of cake.
Monaco Diplomat, Cummins, 38a
Toad Grand Cherokee and Jeep Wrangler, Brake Buddy.
Tom/Barb
Oak Harbor, Wa
Posted: 12/28/18 08:02pm Link  |  Quote  |  Print  |  Notify Moderator
"" The sixth is a pinhole in the front air tank so that will have to be replaced. ""
That would worry me.
2000 Newmar mountain aire 4081 DP, ISC/350 Allison 6 speed, Wrangler JK toad.
MountainAir05
New Mexico
Posted: 12/28/18 08:56pm Link  |  Quote  |  Print  |  Notify Moderator
If you don't have maybe this will help. Don't remember if you have a 2005 or later.
https://www.monacocoach.com/resources/media/manuals/2005_Executive.pdf
Page of 5
