RV.Net Open Roads Forum: Class A Motorhomes: Air Leak UPDATE FIXED!
 > Air Leak UPDATE FIXED!
Page of 5
slickest1
canada
Posted: 12/31/18 04:37pm Link  |  Quote  |  Print  |  Notify Moderator
Executive wrote:
Thanks for all the ideas and suggestions. I've located the leak in the door seal as it appears something got caught and cut the seal near the top of the door. It's possible it just a weathered split but it appears to be a slice across the whole seal. I'm going to try a rubber patch and see if that works. Meanwhile, I've clamped off the hose that feeds the seal and the coach appears to be holding air. That said, I haven't driven it yet so I may have other issues. I'll have the parking brake checked when I have the front tank replaced. I've seen how fast the coach drops when losing air and I don't have the equipment to properly block the chassis, so I don't go underneath it anymore.....Thanks again to everyone and I hope everyone has a safe and enjoyable New Years celebration....Dennis
An easy way to check for the parking brake is to build up the air shut the engine off put chocks or blocks in front and rear of wheels release the park brake and just walk around and listen. You will hear the air leak from outside without going under.
1998 Holiday Rambler Imperial 40 ft.
Dennis and Marcie and Pup the Jack Russell
2 many 2
Posted: 12/31/18 05:27pm Link  |  Quote  |  Print  |  Notify Moderator
Thank you for posting the latest outcome. Please have a safe and happy new year!
Executive
Posted: 12/31/18 09:25pm Link  |  Quote  |  Print  |  Notify Moderator
I'll try that tomorrow after charging my hearing aid batteries. [emoticon] Thanks for the tip....Dennis
A Simple Act of Caring Creates an Endless Ripple
Dennis and Debi Ten Years Full Timing
2014 Chevrolet Equinox LTZ W/ ReadyBrute
CLICK HERE TO VIEW OUR TRAVEL BLOG
MountainAir05
New Mexico
Posted: 01/01/19 08:36am Link  |  Quote  |  Print  |  Notify Moderator
Dennis , These guys have made seals for me if you do not find one.
Roger Anderson
Dynamic Rubber, Inc.
131 Garlisch Drive
Elk Grove Village, IL 60007
randerson@dynamicrubber.com
847.758.0241
Gene
Executive
Posted: 01/01/19 12:36pm Link  |  Quote  |  Print  |  Notify Moderator
Tried that this morning but couldn't hear any air leaking, even with the hearing aids fully charged. Since I will be having the air tank replaced, I'll just let the mechanic find out what's going on. They are two weeks out so I'll rest this post and update once I've gotten the coach back.....Dennis
Executive
Posted: 01/02/19 03:09pm Link  |  Quote  |  Print  |  Notify Moderator
If anyone is subscribed to this thread, I've got an appointment on January 25th to have the coach diagnosed. If it's a parking brake diaphram, they have those in stock and/or get them locally. The air tank is still available from REV at a cost of almost $1300 and an 8 week lead time..[emoticon] I'll post more as info becomes available. Thanks....Dennis
wildmanbaker
Kennewick, Washington
Posted: 01/02/19 03:26pm Link  |  Quote  |  Print  |  Notify Moderator
Dennis, if it were me, I would take the tank to a welding shop and get it repaired at a much lower price, and within a week. Just sayin.
Wildmanbaker
2 many 2
Posted: 01/02/19 06:23pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the up-date. As suggested, I think I would consider welding the tank too. Best of luck [emoticon]
diplomatdon
Blaine, WA
Posted: 01/02/19 07:02pm Link  |  Quote  |  Print  |  Notify Moderator
Dennis, I would measure up the tank and available space and try any major truck distributor. Air tanks are air tanks and maybe I'm wrong but $1300 sounds a little high. Good luck, Don.
Tom/Barb
Oak Harbor, Wa
Posted: 01/02/19 07:46pm Link  |  Quote  |  Print  |  Notify Moderator
I would also get an after market tank. they do come in all sizes, But I would not weld the old tank. the interior condition is a big unknown.
2000 Newmar mountain aire 4081 DP, ISC/350 Allison 6 speed, Wrangler JK toad.
Page of 5
