RV.Net Open Roads Forum: Class A Motorhomes: Air Leak UPDATE FIXED!
 > Air Leak UPDATE FIXED!
Page of 5
MrWizard
Traveling
Posted: 01/02/19 08:38pm Link  |  Quote  |  Print  |  Notify Moderator
is the tank Aluminum or steel, Aluminum doesn't rust
weld and be done
Radiate The Happy
1997 F53 Bounder 36s
wildmanbaker
Kennewick, Washington
Posted: 01/03/19 10:17am Link  |  Quote  |  Print  |  Notify Moderator
I have welded a number of air tanks that had developed leaks. Unless it is an ASME coded tank, you would be surprised on how thin some of them are, especially small tanks. I have even converted hot water tanks into air tanks. Hot water tanks have a working pressure of 150, and burst pressure of 300 psi. I only used the non-glass lined ones.
Wildmanbaker
Executive
Posted: 01/10/19 09:30pm Link  |  Quote  |  Print  |  Notify Moderator
Took the coach in today to have it 'fixed'. Technician spent time going over the coach from stem to stern. Found several air hoses with leaks, one pretty large. Tightened up all fittings and replaced four hoses. No pin hole in air tank, leak was at the fitting. Total cost was $700 but the coach is 100% now. I repaired the door seal myself and it's not leaking either. I'm a happy camper again.....thanks to everyone who responded to my posting. You guys are tops with suggestions and ideas....Dennis
EDUCATION IS IMPORTANT, BUT CAMPING IS IMPORTANTER!
Dennis and Debi Ten Years Full Timing
2014 Chevrolet Equinox LTZ W/ ReadyBrute
CLICK HERE TO VIEW OUR TRAVEL BLOG
2 many 2
Posted: 01/11/19 02:51am Link  |  Quote  |  Print  |  Notify Moderator
Great news! Thanks for the follow up.
bjbear
Cold Lake, AB, Can
Posted: 01/11/19 07:33am Link  |  Quote  |  Print  |  Notify Moderator
Glad you got everything fixed. The number of problems suggests that the system has been deteriorating over time. Everyone with air brakes should perform a pre-trip inspection regularily which will identify problems early before they become a potential safety issue. Truckers do one every day (or are supposed to). I have attached a link to a pre-trip I adapted for an RV from the standard commercial vehicle one.
http://www.visualsc.com/air_brakes.pdf
2006 Monaco Camelot 42-DSQ
09 Blazer 20' Covered Trailer
Toads - '13 GMC Terrain/'11 Wrangler
My Website
wildmanbaker
Posted: 01/11/19 10:28am Link  |  Quote  |  Print  |  Notify Moderator
Alright! A lot more peace of mind now to boot.
Stim
NE Florida
Posted: 01/11/19 05:13pm Link  |  Quote  |  Print  |  Notify Moderator
For anyone dealing with an air leak, a child's hearing can hear them much better than an adult.
Page of 5
