RV.Net Open Roads Forum: Dinghy Towing: Chaser vs. Dinghy
Search only in Dinghy Towing
Open Roads Forum  >  Dinghy Towing  >  General Topics
 > Chaser vs. Dinghy
mleekamp
Washington, IL
Posted: 12/29/18 10:49am Link  |  Quote  |  Print  |  Notify Moderator
Hey all. I recently saw a couple u-tube vids on folks using chaser cars vs. dinghy towing (regardless of dolly, 4 down, etc).
Currently, with our new Class C, I don't have a dinghy set up yet...we've camped local so far (we got the C in late Aug) and wife met us at campsite after work.
Our plans are to make my truck into a dinghy (can be towed flat 4).
But the question I have is...what experiences do any of you have using chaser on long trips vs dinghy? Set up cost is not my concern...just the ease of driving motorhome w/o towing.
Obvious disadvantage is not all being together at the same time, but an advantage would be ability to reverse and less strain on motorhome.
Looking for honest input!
2019 Jayco Redhawk 29XK Class C, Ford V10 E450 chassis
Dinghy: 2005 Jeep Wrangler X, hardtop, auto
donn0128
Pronounced Ore-gun
Posted: 12/29/18 11:10am Link  |  Quote  |  Print  |  Notify Moderator
A lot depends on the MHs chassis and towing ability. So many class Cs are already at or over chassis limits before adding hitch weight towing becomes impractical. Before deciding on anything you need to get some accurate scale weights on your MH loaded ready to travel.
Don,Lorri,and Charlie Bear 2016
8 years OSP Camp Host
The Other Dallas
gbopp
The Keystone State
Posted: 12/29/18 11:21am Link  |  Quote  |  Print  |  Notify Moderator
Another possible option on long trips is, rent a car when you reach your destination.
Or use bicycles?
T18skyguy
Eugene, OR
Posted: 12/29/18 11:27am Link  |  Quote  |  Print  |  Notify Moderator
If you don't mind the extra fuel cost, it's a valid plan. My wife did a chase car for a while, but you lose the advantage of togetherness and she didn't like it for long. Towing four down is fairly easy, but don't know how heavy your truck is. On a long trip, the cost of fuel might equal the camping fees.
Retired Anesthetist. Pilot with mechanic/inspection ratings. 2017 Jayco Greyhawk 31FS .Wife and daughter. Three cats which we must obey. Thorp T18, tons of tools and tons of junk.
Big Katuna
Deland, FL
Posted: 12/29/18 12:00pm Link  |  Quote  |  Print  |  Notify Moderator
We’ve towed a cargo trailer while wife drove a car. It’s ok but not optimum..
My Kharma ran over my Dogma.
wildtoad
Blythewood, SC
Posted: 12/29/18 12:09pm Link  |  Quote  |  Print  |  Notify Moderator
We used a chaser for a while but limited to a couple hundred miles. Anything further we would just try to rent, taxi, Uber or stayed put where we were. Found out that the three options listed were not available everywhere. So when we got our current RV we decided to bite the bullet and got a toad. Now we “don’t leave home without it”.
Tom Wilds
Blythewood, SC
accsys
Green Cove Springs, FL
Posted: 12/29/18 01:13pm Link  |  Quote  |  Print  |  Notify Moderator
I much prefer the dinghy as we can enjoy each other's company, AND she can keep my coffee cup full......just sayin. [emoticon]
John & Doris
Doris and Robbies Blogs
2007 Tiffin Phaeton QDH 40 w/Cat 7 350
2004 Liberty Renegade 4x4 Toad
Roadmaster Falcon 2 tow bar
Air Force One toad braking system
FMCA F380583, PA, Good Sams
maddog348
Bakersfield,CA
Posted: 12/29/18 01:38pm Link  |  Quote  |  Print  |  Notify Moderator
Used toad as a chaser for a few hundred mile on vacation many year ago. Out in the middle of nowhere hit a bad 'dip' leaving a parking lot and tore out the tow cable wiring. WOW!!!! set off the screach alarm. As we had Remco pump in toad didn't want just any yahoo putting it back together. Our installer at home said car would be fine if we stopped every 125/150 miles ~ held the brake down and cycled it thru the gears. Worked fine ~ did use a little more fuel. Didn't have to hook up every day. Had family 2way radio so we could communicate. All in all not too bad.
JM2¢ ~~ YMMV
* This post was edited 12/29/18 01:50pm by maddog348 *
maddog348
Bakersfield,CA
Posted: 12/29/18 01:48pm Link  |  Quote  |  Print  |  Notify Moderator
Hitch weight on a 4down toad??
Y-Guy
Tri-Cities, WA
Posted: 12/29/18 03:47pm Link  |  Quote  |  Print  |  Notify Moderator
We've had our Winnebago for 11 years and no dinghy. For some father off destinations we've rented a car, like our trip to Utah. But for our Oregon/Washington trips we either go without or my wife drives the Jeep. But after these years we've figured it's time. We're no longer taking our boat or ATVs so we can setup the Jeep instead. Since our kids don't go with us we really don't care to drive alone anymore.
The big downside to not having it setup has been the longer drives, somebody to talk with, navigate or help with an issue inside the RV while driving.
2007 Winnebago Sightseer 35J
2011 Jeep Wrangler
 > Chaser vs. Dinghy
