RV.Net Open Roads Forum: Battery disconnect - can I still use my heat?
 > Battery disconnect - can I still use my heat?
ScottyP5947
PNW
Posted: 12/30/18 02:56pm Link  |  Quote  |  Print  |  Notify Moderator
Hello fellow RV friends!
I have a travel trailer and was wondering if I can disconnect my batteries for the winter so that they last longer but still have it plugged into shore power so I can use the heater? Should I turn the converter off too?
Thanks everyone!
Scott
Terryallan
Foothills NC
Posted: 12/30/18 03:18pm Link  |  Quote  |  Print  |  Notify Moderator
I will say you can. Everything in my TT works on shore power, with the battery unhooked. I wouldn't worry about the converter. I can't turn mine off.
Terry & Shay
Coachman Apex 288BH.
2013 F150 XLT Off Road
5.0, 3.73
Lazy Campers
whjco
Lexington, KY
Since most power centers are also a battery charger, I'd just leave the batteries connected. It will not shorten the life of your battery unless there's a problem in the charging circuit of your power center.
Bill J., Lexington, KY
2006 Starcraft 2500RKS 25' Travel Trailer
2015 Ram 2500 Big Horn 6.7 Cummins.
Old-Biscuit
Verde Valley
Posted: 12/30/18 03:25pm Link  |  Quote  |  Print  |  Notify Moderator
YEP^^^^^
If you are going to be plugged into AC power source then leave batteries in place, disconnect on and converter on.....
Converter will supply the DC System AND maintain the batteries with float charge
IF you remove batteries....disconnect off and leave converter on for DC Power....furnace runs on DC
ScottG
Bothell Wa.
Posted: 12/30/18 03:57pm Link  |  Quote  |  Print  |  Notify Moderator
Yes, assuming your converter is roughly ten years old or less.
Scott, Grace and Wesly
2018 Silver Fox 32A.
H0NDA eu2000i
midnightsadie
ohio
Posted: 12/30/18 06:00pm Link  |  Quote  |  Print  |  Notify Moderator
but remember to service the batteries couple times a year check water ,etc.
garym114
Bluff Dale, Texas
Posted: 12/30/18 06:53pm Link  |  Quote  |  Print  |  Notify Moderator
Your batteries would be better off if you disconnected them instead of leaving them on a float charge.
The converter will provide enough to run the heater if you need to.
BB_TX
McKinney, Texas
Posted: 12/30/18 08:36pm Link  |  Quote  |  Print  |  Notify Moderator
Mine stays plugged in any time it is in storage. And since we always have FHU sites, the only time it is not plugged in is when we are on the highway. 11 years and I have replaced the batteries one time. I do check the water regularly.
ScottyP5947
PNW
Posted: 12/30/18 11:54pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the input! My rig is only 2 years old. Sounds like half are saying to just leave the batteries connected and the others say to disconnect. It charges it to 13.1 V, and I do regularly check the water levels. So far so good. I want to install a cut off switch, that'd be nice and easy and then I will disconnect them when not in use.
Most importantly, I appreciate knowing I can just leave the converter on so I can use the heat if I want to use it as a man cave this winter.
Thanks!
Scott
patperry2766
Saginaw Texas
Posted: 12/31/18 04:31am Link  |  Quote  |  Print  |  Notify Moderator
Man cave or potential dog house?
Courage is the feeling you have right before you fully understand the situation
