RV.Net Open Roads Forum: Fifth-Wheels: Heartland RV
 > Heartland RV
neal10a
Madison CT
Posted: 01/03/19 08:13am Link  |  Quote  |  Print  |  Notify Moderator
justme wrote:
Watch out for water intrusion on Big Horn and Landmark roofs. They are TPO/EPDM on laminate with 1/8inch Luan and foam. They are OK to walk on, and That makes them super intolerant to water intrusion as compared to TPO/EPDM on marine grade ply wood. Also, if you plan on solar panels mounted on the roof, there is not much material to mount the panels properly. Any water intrusion will cause bubbling and soft spots of the roof and could be expensive to repair if at all. It is a mystery why Heartland chose to luan instead of Adzel if they were laminating the roofs.
The newer unints may not be laminatied but prior to 2016 they were.
That does not speak well for long Gevity of those trailers.
ReneeG
Meridian, Idaho
Posted: 01/03/19 11:36am Link  |  Quote  |  Print  |  Notify Moderator
We installed solar panels five years ago and inspect our roof regularly. No problems to date.
2011 Bighorn 3055RL
2011 F350 DRW 6.7L 4x4 Diesel Lariat and Hensley BD3
1992 Jeep ZJ and 1978 Coleman Concord Pop-Up for remote camping
Dave & Renee plus (Champ, Molly, Paris, Missy, and Maggie in spirit), Mica and Mabel, both Rat Terriers!
justme
Posted: 01/03/19 05:48pm Link  |  Quote  |  Print  |  Notify Moderator
The problem is that 1/8" luan is not as secure to mount solar panels as 3/8" ply wood. Yes one can mount them to luan, but if you are traveling 60mph into a 20+ mph head wind you are seeing hurican force winds that could play havac on anything secured to luan. Special precautions would be advised. I wonder if Heartland ever offered or even authorized solar panels on those roofs--. I beleive many folks did add them, but they are dealing with unknown risks. There are aluminum cross members every 4ft that one could ankor those panels to, but I don't think it is practicle unless they use unistrut ankored to those aluminum cross memebers with the panels ankered to the unistrut. Most RVs use 3/8" ply woods with cross members spaced at 16" which would provide a secure roof for mounting things on--- not to mention that any potential water intrusion damage would be significantly lessoned
Jlsr
Posted: 01/03/19 09:34pm Link  |  Quote  |  Print  |  Notify Moderator
If I were in your shoes I'd keep that Carriage Royale. Far superior build quality than the 5th wheels on the market now. Seems like you'd be taking a big step down for one of the brands mentioned.
All the best,
2015 Lifestyle Luxury RV LS36FW
dblr
Newark De
Posted: 01/04/19 05:02am Link  |  Quote  |  Print  |  Notify Moderator
Just a thought, have you ever considered refurbishing and upgrading your current Royals? You could check with Kansas RV has they do a lot of that type work, might even be cheaper in the long run.
2017 River Stone Legacy 38MB
2001 Kenworth T2000
2009 Smart on the deck.
ReneeG
Meridian, Idaho
Posted: 01/04/19 03:21pm Link  |  Quote  |  Print  |  Notify Moderator
As I said, we inspect and there is no movement, nothing that is loose with the panels or leaking with the roof. Our unit is a 2011 model and one of the best built. I would not buy a new one today.
Mary1
Ontario, Canada
Posted: 01/08/19 06:27pm Link  |  Quote  |  Print  |  Notify Moderator
Yes keeping the Royal, earlier tonight I posted on lots of comments about the Carriage products present and past owner. And weird I forgot my username I figured it must be right, not sure how I was accepted in with username Broant which I have used in the past for other forums. Anyways, after reading all those posts I realized my husband had reasons for not parting with it. So we will see if we can change the interior with a more modern look. thanks all
 > Heartland RV
