RV.Net Open Roads Forum: Class A Motorhomes: Electrical cord power reel
 > Electrical cord power reel
Goldencrazy
madison wi
Posted: 01/01/19 06:49pm Link  |  Quote  |  Print  |  Notify Moderator
I am fortunate to have a power reel. 2013 Itasca elipse. It stoped resonding. Any ideas where to start to troublshoot?
GPWayne
Lake Stevens. WA
Posted: 01/01/19 07:40pm Link  |  Quote  |  Print  |  Notify Moderator
First off what is not working?
I would guess the reel is not turning.
Do you have a hand held remote or a switch?
Do you have power to the system?
Do you have a bypass lever to let you operate the reel manually? If so is in power mode?
CA Traveler
The Western States
Posted: 01/01/19 07:51pm Link  |  Quote  |  Print  |  Notify Moderator
Check:
1. The fuse
2. The switch
3. The voltage
And report back.
2004 CR-V and 2014 Grand Cherokee Overland
Bob
FIRE UP
Lake Havasu City AZ
Posted: 01/01/19 08:47pm Link  |  Quote  |  Print  |  Notify Moderator
Yep,
We need a bit more info on just what's wrong. We too have a power shore power cord. I didn't really know how it all worked when we first got the coach. But, with a little digging around, I figured out how certain things worked on it. I don't know if the OPs system is similar or not but, in short, I have two roller guides, one on each side of the cord as it winds in or out. Each of those rollers has a micro-switch on it.
As the cord is rewound into the barrel, it will touch either roller and, whatever roller it's touching, will trigger the micro switch. But, nothing happens unless BOTH rollers are touching their respective switches. That can't happen with just the regular cord housing. But, there is a collar clamped round the cord housing about 18" or so from the plug. When winding in that cord, and the collar touches both rollers, then both micro switches are triggered and, THAT will stop the motor from winding in the cord.
Now, can this be the OPs issue, not a clue. When he gets back with some info on just what the problem is, we'll be able to help better.
Scott
Scott and Karla
SDFD RETIRED
2011 GMC Sierra 1500 Ext Cab 4x4 Toad
2008 Caliente Red LVL II GL 1800 Goldwing
KI60ND
Goldencrazy
madison wi
Posted: 01/02/19 01:24am Link  |  Quote  |  Print  |  Notify Moderator
Sorry. I am on the road. Will dive into it when we arrive at Florida destination tomorrow. All i know now is that when i push the switch i get no response. I haven’t even checked 12 volt fuses. I don’t know if this has a separate fuse or breaker. I will let you know. What you all have provided so far is helpful as i know nothing about it.
Bill.Satellite
Full-timer
Posted: 01/02/19 06:08am Link  |  Quote  |  Print  |  Notify Moderator
Can you hear a motor running but getting no movement (broken gear and likely fixable) or is the unit making no noise (likely a fuse)?
What I post is my 2 cents and nothing more. Please don't read anything into my post that's not there. If you disagree, that's OK.
Can't we all just get along?
