RV.Net Open Roads Forum: Fifth-Wheels: Critique my winterize technique
 > Critique my winterize technique
tim665214
Slidell
Posted: 01/02/19 11:36am Link  |  Quote  |  Print  |  Notify Moderator
I live in N.E. Texas, so while we do not have brutal cold weather, we do get below freezing. Here is a quick way that I have found to quickly winterize. Since we will use our 5th wheel during the winter, I will probably be doing this several times this winter. Let me know if this is adequate.
1. Drain the FW holding tank.
2. Drain and bypass the Hot water tank.
3. Blow out the black tank flush lines.
4. Using the prmitive fill line, run antifreeze through all faucets until I see pink.
5. Pour some antifreeze in all p-traps, and comode.
6. Drain the grey water tanks to get rid of water that just got dumped in there.
Will this work? This bypasses the steps I did last year which was blowing out all of the lines with air, before adding antifreeze. Also, if I make sure there is pink stuff in all of the lines, do I have to mess with opening the low point valves, since they are in a difficult location? I keep my 5th wheel plugged in all of the time, so the batteries are always topped off.
schlep1967
Harrisburg, PA
Posted: 01/02/19 11:56am Link  |  Quote  |  Print  |  Notify Moderator
I would open up the low point drains. If you have pure water sitting in the bottom of those lines outside the trailer, they will freeze and most likely crack. Not the worst place to have a leak in the spring but still a pain to have to fix.
2008 Dodge Ram 2500 Diesel
2009 Open Range 385RLS
Pull-Rite Super Glide
djousma
SW Michigan
Posted: 01/02/19 12:23pm Link  |  Quote  |  Print  |  Notify Moderator
do you have ice maker in the refrigerator? You are going to want to either blow the line with air, or do A/F.
Dave
2016 F350 Lariat 4x4 FX4 SRW CC SB 6.7 Magnetic Metallic
2017 Forest River Cardinal 3850RL
padredw
East Texas
Posted: 01/02/19 01:14pm Link  |  Quote  |  Print  |  Notify Moderator
I also live in North East Texas. I follow all your other steps but have never done number 4. I have had four fifth-wheels over a 20 year period, and have never had freeze damage. If the temps got really low, I would turn on some heat in the trailer. I do open the low point drains and blow out the lines. My "shed" is open on three sides. This is not advise, just a personal report of my experience.
Super_Dave
Harrisville, UT
Posted: 01/02/19 01:30pm Link  |  Quote  |  Print  |  Notify Moderator
I was told that my trailer doesn’t have low point drains. Is that possible?
Truck: 2006 Dodge 3500 Dually
Rig: 2018 Big Country 3155 RLK
Boat: 2003 Jetcraft 2125 - Yamaha 150 HP & 8 HP Kicker
Dave H M
IL
Posted: 01/02/19 01:34pm Link  |  Quote  |  Print  |  Notify Moderator
Do you have an outside shower?
How about the city water inlet?
MFL
Midwest
Posted: 01/02/19 02:00pm Link  |  Quote  |  Print  |  Notify Moderator
Possible...yes Dave, I don't know why they would be eliminated on some models, but I have heard some Big Country owners say they do not have them.
Jerry
old guy
Oregon (pronounced Or e gun)
Posted: 01/02/19 04:53pm Link  |  Quote  |  Print  |  Notify Moderator
if the low point drains are hard to get to, do like I did with mine. I took off the caps on the drains and added pipe and manual shut offs, to a point on the edge of the TT so I could reach them. sure made a difference when I winterize my TT. I also did that to my fresh water tank drain. at least I don't have to lay on the wet ground now to drain the TT.
Chakara
New Mexico
Posted: 01/02/19 06:13pm Link  |  Quote  |  Print  |  Notify Moderator
Ditto this - don't ask.... [emoticon]
- 2005 Dodge 2500 5.9 6spd / Pacbrake / Airbags
- 2018 Arctic Fox 27-5L 5th Wheel
- SOLD: 2007 Keystone Raptor 299MP 33' 5th Toyhauler
- SOLD: 2010 Starcraft Autumn Ridge 246RKS 28'
- SOLD: 2004 Casita Spirit Deluxe
- SOLD: 2007 Dodge Dakota fiberglass topper
TXiceman
Full Time RVer
Posted: 01/02/19 06:17pm Link  |  Quote  |  Print  |  Notify Moderator
We lived in northeast Oklahoma and I never put pink stuff in the pipes. I drained the water heater, drained all low point drains, and used air to blow out all of the lines, toilet flush valve and water pump. Then I put pink stuff in the traps. Never had any issues with this procedure.
Ken
Amateur Radio Operator.
