RV.Net Open Roads Forum: Fifth-Wheels: Critique my winterize technique
 > Critique my winterize technique
TXiceman
Full Time RVer
Posted: 01/02/19 06:17pm Link  |  Quote  |  Print  |  Notify Moderator
We lived in northeast Oklahoma and I never put pink stuff in the pipes. I drained the water heater, drained all low point drains, and used air to blow out all of the lines, toilet flush valve and water pump. Then I put pink stuff in the traps. Never had any issues with this procedure.
Ken
Amateur Radio Operator.
sgfrye
north carolina
Posted: 01/04/19 07:04am Link  |  Quote  |  Print  |  Notify Moderator
Ken
x2 for our north carolina winters. added bonus we are ready to use camper on a spur of the moment trip when temps hit 50's or 60's on a nice weekend
RollandB
Albany, Or
Posted: 01/05/19 07:55am Link  |  Quote  |  Print  |  Notify Moderator
I do the same basic steps and only winterize the waterlines with air. We us ours all months of the year, but being it’s stored deal with making sure it doesn’t freeze. We get some freezing temps but usually not for long periods. The same steps as you do worked one winter when we had aboutn10 days of single digit temps.
I’ll also leave the low point drains open as well as all faucets once the lines are blown out.
2005 Silverado 3500 Crew Cab Long Box, Duramax/Allison, B&W Companion, TST507's
2016 Artic Fox 27-5L
pyoung47
MO
Posted: 01/05/19 08:11am Link  |  Quote  |  Print  |  Notify Moderator
I just realized that I've been forgetting to purge and fill with antifreeze my washer connections in the bedroom. We don't have a washer installed, and I kinda forgot about these.
Crodad
Lafayette, LA
Posted: 01/07/19 02:15pm Link  |  Quote  |  Print  |  Notify Moderator
I'm in South Louisiana, so all I do is drain the FW tank, open the low point drains. When we get a freeze I turn on the Grey and black tank heaters and set the inside furnace to 40 degrees. If you don't have tank heaters, the inside furnace heated them enough.
2008 F-250 PSD 4x2 Lariat
2016 Silverback 31RK
