RV.Net Open Roads Forum: Over Slope my leveling system ? Newby question
 > Over Slope my leveling system ? Newby question
jbstack28
Posted: 01/03/19 10:45am Link  |  Quote  |  Print  |  Notify Moderator
Ok, newby question. Where my coach is stored it is not near level maybe 2025 down slope from Port to starboard. And that is a guess. So I want to put out my slide to pack, and maybe hang with a beer afterward. So I stack up blocks under starboard side, able to get her level then the overslope light comes on. Also I note the starboard tires are off the ground. (Bad thing ?) Oh I have a 2010 Phaeton 40TD.
So now my day is done, I do not want to leave in this position. So I push store button. Terrible noise below, but visually everything looks ok. Confirmed landing gear still worked.
Can this be done safely or move the rig somewhere everytime I want to put the slides out?
Thanks so much,
Big Katuna
Deland, FL
Posted: 01/03/19 11:29am Link  |  Quote  |  Print  |  Notify Moderator
You need to be level to put slides out. Read your instruction manual..
Some mfrs say to put slide out then level but MOST say level first, motor running.
And when your rear wheels are off the ground it can slide.
RVs twist and flex. I’m surprised slides work as well as they do.
My Kharma ran over my Dogma.
DutchmenSport
On the road
Posted: 01/03/19 11:30am Link  |  Quote  |  Print  |  Notify Moderator
Delete
* This post was edited 01/20/19 07:11pm by DutchmenSport *
Crestview area, Inyo County, California
Posted: 01/03/19 12:03pm Link  |  Quote  |  Print  |  Notify Moderator
MH rear wheels off the ground makes me nervous.
2015 Winnebago 2101DS TT & Tahoe LTZ, 300 watts WindyNation solar-parallel & MPPT, Trojan T-125s. TALL flagpole for US flag. Prefer USFS, COE, BLM, NPS, TVA, USF&WS, state & county camps. Bicyclist! 14 year Army vet - 11B40 then 11A - old MOS 1542 & 1560.
K Charles
Connecticut
Posted: 01/03/19 02:43pm Link  |  Quote  |  Print  |  Notify Moderator
What DutchmenSport said is the only answer.
dougrainer
Carrolton, Texas
Posted: 01/03/19 04:31pm Link  |  Quote  |  Print  |  Notify Moderator
EXCESS SLOPE. NOT Overslope. Excess slope just means ONE of your Jacks has reached its FULL extension and cannot extend more to level your RV. So, the Excess Slope light comes ON and shuts the system down. The System has NO WAY to know what the extent of your slope really is. It uses the factor of one jack reaching full extension to signal you are on an excess slope. You can do as you have done and install boards under the side that is lower than the other to get more lift from the side that needs to come up higher. BUT, lifting the tires OFF the ground is a bad practice. Since you have a Tiffin, it would be better to extend the Slides BEFORE extending the jacks. Then RETRACT the jacks before retracting the slides. When you use blocks to get more lift from the Jacks, that puts a bind on the frame/chassis. If the Motorhome is just leaning to one side due to the angle of the ground, then there is no problem operating the slides before extending the jacks. Now, if the ground is very uneven and the corners are twisted, then jacking would be better for the slides. Doug
