RV.Net Open Roads Forum: Fifth-Wheels: Hitch storage
 > Hitch storage
Ernie Fergler
Iowa
Posted: 01/03/19 03:41pm Link  |  Quote  |  Print  |  Notify Moderator
Traded tv awhile back , and the new one came with a factory hitch. Haven't needed to remove the hitch yet but the day will come. The shipping weight of the hitch is over200 lbs; too much for me to lift/ carry by myself. Was wondering if anyone ever left their hitch hanging from the kingpin on the trailer.? Simply release the frame latches, lift the landing gear, and drive away. Seems like alot of weight to be hanging,though. Anybody ever try it? The only other way i can think to get it out would be to disassemble it. Looks like it breaks down in 5 or 6 pieces. Vehicle is a '16 Ram dualie, 8 ft bed, w/ Mopar (curt) 25K hitch, 4wd. Anxious to hear your thoughts.
Ernie
2004 Ram 3500 DRW 2 WD
2012 Sabre 31 ckts
Bipeflier
Centralia, MO
Posted: 01/03/19 03:51pm Link  |  Quote  |  Print  |  Notify Moderator
Search these forums. Done all the time.
2010 Cruiser CF30SK Patriot
2016 3500 Duramax
1950 Right Hand Seat GPS (she tells me where to go)
Dave H M
IL
Posted: 01/03/19 04:28pm Link  |  Quote  |  Print  |  Notify Moderator
My hitch has been hanging on the king pin for quite some time.
What is hanging 200 lbs compared to carrying 2250?
old guy
Oregon (pronounced Or e gun)
Posted: 01/03/19 04:42pm Link  |  Quote  |  Print  |  Notify Moderator
make your self a tri pod hitch remover. with a pulley up above and lift it out of the truck and pull the truck out of the way and lower it to the ground for storage or put it on a platform on wheels and move to storage out of site out of mind
agesilaus
North Florida
Posted: 01/03/19 04:47pm Link  |  Quote  |  Print  |  Notify Moderator
I just made a table at the same height as the truck tail gate. I detach the hitch and just slide it onto the table. Made it out of 2x4's, but it needs to be well braced to take the weight. My hitch is the type that doesn't have rails in the bed if yours is the type with rails then this may not work. The hitch is heavy but slides easily.
Arctic Fox 25Y Travel Trailer
Straightline dual cam hitch
Superbumper
rhagfo
Portland, OR
Posted: 01/03/19 04:51pm Link  |  Quote  |  Print  |  Notify Moderator
Ernie
Congratulations on the new TV, just got one like it.
The hitch should easily break down to at least two, if not three parts which can easily be handled.
I have see many hitches hanging from the front of a 5er, I don't see an issue.
hornet28
Muskegon
Posted: 01/03/19 05:37pm Link  |  Quote  |  Print  |  Notify Moderator
You could use an overhead pulley set-up in you garage or a cherry picker then set it on a wheeled cart
Cummins12V98
on the road
Posted: 01/03/19 06:12pm Link  |  Quote  |  Print  |  Notify Moderator
It is a two part hitch, get a friend or a young stud to give you a hand.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
Ernie Fergler
Iowa
Posted: 01/03/19 06:45pm Link  |  Quote  |  Print  |  Notify Moderator
Thx for the ideas guys. Had thought about lifts, but that brought up the problem of building and storing that contraption too. Space is scarce for me. Small house, small lot, single car garage and small storage room 2 miles away. Really just wanted to know if my idea was ok.
Special thanks to Bipeflier for your insightful and prompt response.
Ernie
valhalla360
No paticular place.
Posted: 01/04/19 12:48am Link  |  Quote  |  Print  |  Notify Moderator
Make sure the latch is locked, so it doesn't fall if someone accidentally pulls the lever...but otherwise it's a great option.
Keep in mind your average 5th wheel pin is designed to take 3000+ pounds and when you hit a pothole, the force could be up or down... reality is in a dynamic driving situation, it could see instantaneous loads several times that amount...200 pounds of static loading is nothing.
Tammy & Mike
Ford F250 V10
2008 Copper Canyon 5er
Catalac Catamaran 34'
Full Time spliting time between boat and 5er
 > Hitch storage
