RV.Net Open Roads Forum: OMG My new TV is Soooo Big and tall!
Search only in Tow Vehicles
 > OMG My new TV is Soooo Big and tall!
rhagfo
Portland, OR
Posted: 01/03/19 05:53pm Link  |  Quote  |  Print  |  Notify Moderator
We see people posting statements when they either go from an 150/1500 to a 250/2500. We also see it when many step up from a 250/2500 to a 350/3500 DRW.
Well seeing how I didn't trade my old TV on the new, I had it for a little side by side comparison
So first from the front, yep the hood is a bit taller, maybe a tic wider feels about the same width.
Now a side view at the front,like I said above I think the hood is just a tad taller, maybe an inch.
Next length and a bit of height, the length looks to be about 18" maybe a bit less. The height is 1" taller for the 2016 based on measurements at the Tailgate.
Yep the new DRW has a sweet set of Hips! Sure is wider than the 2001, but still easily fits in a standard highway lane.
Now rear to rear I see hardly and difference, other than with the 2016 the rear tire looks closer to the rear. That should make towing smoother.
So all in all the new 2016, is just a tad bit larger than our current 2001, the part that really amazed me was the height at the Tailgate is within an INCH of the same height.
I will say the cab feels much larger than the 2001, maybe it is the bucket seats and very nice console between the driver and passenger.
So from now on I will take with a grain of salt statements like "It is just too big to drive in the city" or "It is too big to be a daily driver"
Yes I will be aware of the hips for a bit, but then they will be second nature.
near La Cuesta Encantada
Posted: 01/03/19 06:04pm Link  |  Quote  |  Print  |  Notify Moderator
That’s a lot of beef in your driveway.
2015 Winnebago 2101DS TT & Tahoe LTZ, 300 watts WindyNation solar-parallel & MPPT, Trojan T-125s. TALL flagpole for US flag. Prefer USFS, COE, BLM, NPS, TVA, USF&WS, state & county camps. Bicyclist! 14 year Army vet - 11B40 then 11A - old MOS 1542 & 1560.
agesilaus
North Florida
Posted: 01/03/19 06:09pm Link  |  Quote  |  Print  |  Notify Moderator
It definitely makes no sense to say there is a visual difference between a 3/4 and 1 ton. They are the same unless the one ton is a drw.
Arctic Fox 25Y Travel Trailer
Straightline dual cam hitch
Superbumper
old guy
Oregon (pronounced Or e gun)
Posted: 01/03/19 06:27pm Link  |  Quote  |  Print  |  Notify Moderator
IF there is no big difference then why the cost difference
Cummins12V98
on the road
Posted: 01/03/19 06:46pm Link  |  Quote  |  Print  |  Notify Moderator
Longer wheelbase for sure makes for a better ride. There is NO comparison between my 15 DRW's ride and my 01 2500 RAM 4x4 Sport basically the same as your truck.
I'm betting the hipster will compress more than the 01 when loaded.
Russ run 80 psi in the fronts ALL the time. Get the front aligned ASAP to 1/64-1/32 toe. The factory toe is 1/4 and this causes outside tire stepping, been there dun that on two Dually RAM's. Run the rears at 35 unless towing and 5psi above what your rear axle loaded weight compares to the load/inflation chart for your tires. 65 will be WAYYYY overkill for the rears towing for your RV.
Use ONLY Fleetguard, Mopar and Raycor filters.
I am sure you know most of this!!!
* This post was edited 01/03/19 06:58pm by Cummins12V98 *
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
jaycocamprs
Ringgold Georgia
Posted: 01/03/19 06:51pm Link  |  Quote  |  Print  |  Notify Moderator
You are lucky with the Ram then. We had to deal with 2 deeper bed. That was from a 05 to 18 DRW Chevy. The old 05 pulled the trailer just fine, but the L5P is SWEET.
2018 Silverado 3500 DRW
2011 Montana Mountaineer 285RLD
Me Again
Sunbird(Wa)/snowbird(Az)
Posted: 01/03/19 07:03pm Link  |  Quote  |  Print  |  Notify Moderator
15 years????
Learjet
Louisiana
Posted: 01/03/19 07:18pm Link  |  Quote  |  Print  |  Notify Moderator
nice truck [emoticon]
2017 Ram Big Horn, DRW Long Box, 4x4, Cummins, Aisin, 3.73
2015 Wildcat 317RL, MoRryde rubber pin box, Titan Disc Brakes, Trojan T105
B&W Ram Companion
Yamaha EF2600c tri-fuel generator
Champion Model 46595- 3000/3500w
rhagfo
Portland, OR
Posted: 01/03/19 07:22pm Link  |  Quote  |  Print  |  Notify Moderator
The DRW is a $1,295 option, and just about $1,000 for a 3500 SRW over a 2500 likely to cover springs and tires, badge, and the larger GVWR number on the VIN sticker. [emoticon]
ScottG
Bothell Wa.
Posted: 01/03/19 07:39pm Link  |  Quote  |  Print  |  Notify Moderator
If your new truck has rear air suspension, it may be slightly lower than the all spring models.
I remember when My 03 was new and parked next to a dually. The dually was at least 2 or 3 inches taller.
Scott, Grace and Wesly
2018 Silver Fox 32A.
H0NDA eu2000i
