RV.Net Open Roads Forum: Travel Trailers: Four Season Travel Trailers Quieter Inside?
 > Four Season Travel Trailers Quieter Inside?
profdant139
Posted: 01/04/19 09:38am Link  |  Quote  |  Print  |  Notify Moderator
We had an uninsulated aluminum trailer -- noisy! We then got a fully insulated fiberglass trailer of the same size from the same manufacturer -- thick styrofoam in the walls, ceiling, and floor. Much quieter.
We don't have dual pane windows -- I am sure that those would cut down on the noise even more.
Our trips -- pix and text
About our trailer
"A journey of a thousand miles begins with a single list."
B.O. Plenty
Minnesota
Posted: 01/04/19 09:54am Link  |  Quote  |  Print  |  Notify Moderator
The term 4 season is meaningless. There is no industry standard so it might not be anything more than a decal and a bunch of hype. Choose carefully and make sure it has what you want. Are there quieter RVs? Yes. We have dual pane windows and heavier insulation and it is much quieter than our previous rig.
B.O.
Former Ram/Cummins owner
2015 Silverado 3500 D/A DRW
Yup I'm a fanboy!
2016 Cedar Creek 36CKTS
goducks10
There
Posted: 01/04/19 12:20pm Link  |  Quote  |  Print  |  Notify Moderator
4 seasons, Arctic Package, Polar Package, Arctic 4 Season Package, CLIMATECH® COLD WEATHER ALL SEASONS INSULATION PACKAGE, Polar Package Plus, etc.
It can be one or more of the following, added insulation in the floor, roof, front cap, slide floor, enclosed valves, heated tanks, heated enclosed tanks, etc.
profdant139
Posted: 01/04/19 12:45pm Link  |  Quote  |  Print  |  Notify Moderator
Here is an idea when you are shopping for a quiet trailer -- install a decibel meter app on your phone. Bring a bluetooth speaker to the dealership. Put the speaker ten feet from the trailer. Play a song of known volume. Note the decibel reading. That gives you a benchmark for each trailer's soundproofing.
Given that RV parks (especially) are often in noisy places (near freeways and trains), this may be a valuable way to compare trailers.
trail-explorer
NM
Posted: 01/04/19 03:34pm Link  |  Quote  |  Print  |  Notify Moderator
bjkb1f wrote:
My wife and I were talking about it and she asked me if the added insulation and insulated windows of a four season camper would make it quieter inside. I would assume so, but is this correct?
Yes, it will be quieter. Thermal pane windows help reduce the noise as well.
Bob
trail-explorer
NM
Posted: 01/04/19 03:35pm Link  |  Quote  |  Print  |  Notify Moderator
donn0128 wrote:
If you could find an RV that used block foam instead of fiberglas that would be a bonus.
Arctic Fox and Outdoors RV use block foam.
trail-explorer
NM
Posted: 01/04/19 03:37pm Link  |  Quote  |  Print  |  Notify Moderator
Nice thing about Arctic Fox and Outdoors RV, is that "they is what they is" - meaning you don't have to "add an option package" to get more insulation and their 4 season rating.
goducks10
There
Posted: 01/04/19 04:38pm Link  |  Quote  |  Print  |  Notify Moderator
So true. And they don't advertise fictitious high R values either.
* This post was edited 01/04/19 04:55pm by goducks10 *
mosseater
Dillsburg, PA
Posted: 01/04/19 05:47pm Link  |  Quote  |  Print  |  Notify Moderator
This was a major reason we ended up with our Sunset Creek. After looking at several on a very rainy day, it dawned on us that is was much quieter in the Sunset Creek compared to the ones parked right next to us. As traffic rushed by on the wet pavement, we went back and forth between the different trailers comparing sound levels and the difference was dramatic. I have stayed the night comfy inside at 5 degrees and 120 degrees. The climate systems work to keep up, but it's doable. Not sure how the quality is since Winnebago took over.
Sunset Creek 298 BH
marcsbigfoot20b27
Phx
Posted: 01/04/19 06:52pm Link  |  Quote  |  Print  |  Notify Moderator
TurnThePage wrote:
I've heard it mentioned that the noise is muffled pretty well from inside Bigfoot brand travel trailers.
My Bigfoot is “4 season” with winter package, has Fibrecore walls /floor/ ceiling, dual pane windows and heated enclosed tanks and valves. It is pretty quiet.
Very first time I took it camping on the rim, I forgot to put my trout gut filled garbage bag/can away at night. Woke up in the morning to see the bag shredded by a bear.....never heard a thing, lol.
