RV.Net Open Roads Forum: General RVing Issues: Squirrels
 > Squirrels
Trixie47
Orlando, Fl
Posted: 01/04/19 09:12am Link  |  Quote  |  Print  |  Notify Moderator
HELP Have a 5ver parked in our yard here in Central Florida. We have a great many squirrels in our area and believe they have been in the camper..chewed toilet paper strewn around. My question: what is good to put out to keep them out of the camper....I know some have said irish spring soap for rodents...will it work in this instance ?
2008 Chevrolet Silverado Crew Cab DW
2012 Keystone Avalanche...4 Slides
swphotobug
varous
Posted: 01/04/19 09:16am Link  |  Quote  |  Print  |  Notify Moderator
That sounds like mice. Check all your drawers for a little nest. We had the problem and put original Irish Spring all over the place, especially under the drawers. Never had a problem since.
If you are sure you have squirrels maybe this woudl work.
donn0128
Pronounced Ore-gun
I would guess mice. Regardless though you need to seal ALL openings. Deterrents simply dont work. The only sure fire way is stopping them getting in.
DutchmenSport
Over There
Posted: 01/04/19 09:18am Link  |  Quote  |  Print  |  Notify Moderator
Delete
* This post was edited 01/20/19 07:10pm by DutchmenSport *
Tachdriver
Louisville, KY
Posted: 01/04/19 10:18am Link  |  Quote  |  Print  |  Notify Moderator
I stayed at Ft. Desoto and noticed a plethora of squirrels and birds on the roof. Even think two holes were started by birds, none the less I bought a plastic owl at Home Depot and put it on a pole near the roof...the problem quickly disappeared.
Perhaps a few near your rig would help.
janstey58
Glenwood, IA
Posted: 01/04/19 10:47am Link  |  Quote  |  Print  |  Notify Moderator
Pure Peppermint Oil soaked cotton balls in your answer. Has worked for us for over 10 years, no mice.
Jeff and Kim
2015 Fleetwood Discovery 40E
Freightliner Chassis 380HP DP
2012 Ford Escape Limited Toad
westernrvparkowner
montana
Posted: 01/04/19 11:37am Link  |  Quote  |  Print  |  Notify Moderator
Squirrels are rats with better press agents. But I have to agree, your problem sounds more like the work of their smaller relative, the mouse. With squirrels, you would likely find larger holes chewed out, twigs and nuts squirreled away (pun intended) and a whole lot of the outside brought inside. You have to go republican on squirrels and build a wall, deterrence is generally not effective.
memtb
Wyoming
Posted: 01/04/19 12:27pm Link  |  Quote  |  Print  |  Notify Moderator
An air rifle and a good recipe...would be a “two for one”! [emoticon]
Todd & Marianne
Miniature Schnauzer's - Sundai, Nellie & Maggie Mae
2007 Dodge Ram 3500, 6.7 Cummins, 6 speed manual, 3.73 ratio, 4x4
2004 Teton Grand Freedom, 39'
2007 Bigfoot 30MH26Sl
Jebby14
Windsor Ontario
Posted: 01/04/19 12:32pm Link  |  Quote  |  Print  |  Notify Moderator
lock a badger in the 5er?
deterrents don't work find the openings and seal them up
If it moves and it shouldn't..... duct tape
if it doesn't move and it should.....WD40
if all else fails .....BFH
JaxDad
Greater Toronto Area
Posted: 01/04/19 12:40pm Link  |  Quote  |  Print  |  Notify Moderator
DutchmenSport wrote:
A a dog. Really, they are your best defense against squirrels.
All we have do is simply say the word, "squirrel" and both our dachshunds go insane! They're good at chasing them, lousy at actually catching them ... that's ok, it gives the dogs good exercise chasing them.
It must be the short legs, our Jack (Parson) Russell's catch them nearly every time. [emoticon]
 > Squirrels
