RV.Net Open Roads Forum: Class C Motorhomes: TV antenna splitter
 > TV antenna splitter
okiejoe
Oklahoma City
Posted: 01/04/19 02:25pm Link  |  Quote  |  Print  |  Notify Moderator
I have a 2015 Thor Chateau 31W and I am trying to locate the antenna splitter, all I have found is switch plate for antenna booster and antenna coaxial connections but no splitter. I have a dish satalite receiver with one cable going into it then one out but I have 3 TVs in the unit one outside one in the back bedroom and one outside in a compartment so has anyone found the location to send signals to all the TVs
ScottG
Bothell Wa.
Posted: 01/04/19 02:39pm Link  |  Quote  |  Print  |  Notify Moderator
Splitters are usually built into the ant. P.S. (your wall switch thingy)
It should have an output for each TV.
Scott, Grace and Wesly
2018 Silver Fox 32A.
H0NDA eu2000i
RoyB
King George, VA
Posted: 01/04/19 02:56pm Link  |  Quote  |  Print  |  Notify Moderator
Here is a neat diagram of the ANTENNA WALL PLATE my two trailers have...
I never had much luck trying to use the so called SAT TV outside connections... Neve could get past the outside trailer TV splitter to grab the required SAT ANTENNA DC VOLAGE to operate the dish...
The only way I could ever get my portable SAT TV to work was to run two RG cables into the trailer from the two SAT OUTPUTs on the dish head and connect to a SAT RCVR at each location we wanted to watch SAT TV. Then I would run VIDEO cables from the SAT RCVR to the VIDEO INPUTS to the TV we wanted to watch it on. Then use the TV control to select the video input for SAT TV or CABLE for regular TV coming in from the cable or outside Batwing antenna...
Roy Ken
D.E.Bishop
Eagle Rock, CA
Posted: 01/04/19 04:01pm Link  |  Quote  |  Print  |  Notify Moderator
Are you asking how to send satellite signals to all three sets using the antenna splitter?
"I travel not to go anywhere, but to go. I travel for travel's sake. The great affair is to go". R. L. Stevenson
David Bishop
2002 Winnebago Adventurer 32V
95 Suzuki Sidekick 4X4
Stowmaster 5000
okiejoe
Oklahoma City
Posted: 01/04/19 05:31pm Link  |  Quote  |  Print  |  Notify Moderator
Ok, thanks for the picture, looks like it may be behind the amplifier switch. I’ll pull it and see. My problem is there is a satellite dome installed on top of the roof am
Nd all 3 TVs are connected to it, the satellite receiver is connected via coaxable antenna cable and all TVs have a snowy picture but if I run an HDMI cable from receiver to big TV up from its crystal clear for that TV
YC 1
Yuba City Calif./ Auburndale Florida
Posted: 01/05/19 03:27am Link  |  Quote  |  Print  |  Notify Moderator
If your sat box has a coax output to feed to a television you can plug it into the middle coax position on the back of the panel shown. Of course this removes your park cable input. Your sat box would have an output on a specific channel on the tv most likely and you change channels via the box of course.
You must have the wall box turned off when using the satellite signal or you will get snow from the roof antenna interference.
If this information works for you there are some simple modifications to the wall plate while you have it out that will make things more flexible
H/R Endeavor 2008
2013 Ford Edge toad
Full Timers
Healeyman
Carrollton, TX
Posted: 01/07/19 09:28am Link  |  Quote  |  Print  |  Notify Moderator
HERE ya' go.
Tim
houstonstroker
Houston, TX
Posted: 01/07/19 03:14pm Link  |  Quote  |  Print  |  Notify Moderator
Is the picture snowy on OTA antenna or cable?
TV 2002 Ford F-250 Powerstroke 4WD Crew Cab
5th Wheel 2009 KZ Spree 305BH
okiejoe
Oklahoma City
Posted: 01/08/19 09:59pm Link  |  Quote  |  Print  |  Notify Moderator
No, fine on OTA
houstonstroker
Houston, TX
Posted: 01/11/19 11:59am Link  |  Quote  |  Print  |  Notify Moderator
OK Fine on OTA, so you know to turn off the booster before you try to scan for cable channels, yes?
