RV.Net Open Roads Forum: Fifth-Wheels: Lubricating the landing gear
 > Lubricating the landing gear
pyoung47
MO
Posted: 01/05/19 01:44pm Link  |  Quote  |  Print  |  Notify Moderator
I learned on the Montana forum that my landing gear has grease zerks available for lubrication. These are easily accessible from the each of the propane compartments. The zerks are located on the front of the square tube, one near the gears at the top and the other near the nut about half way down. It also has a cover that can be removed which exposes the gears at the top, which will allow grease to be applied directly.
I'm passing this along to those, like me, who didn't know this existed. My previous fiver does not have these fittings, and I never thought to lubricate the landing gear.
This is another example of the lack of documentation that comes with a camper. In my case, the manual is written to cover every model that they make, and there is no reference to lubricating the landing gear.
For a few hundred bucks per model, they could hire someone to write up a model specific manual which would include this type of information. I've lost track of the postings I've seen of folks who were unable to find one of the dump valves or other seemingly obvious features.
Of course, the dealer should go over all of these things, but I bought this unit used from a private party. I bought the previous camper new, and the dealer sent one of their staff to go through the camper with me -- I ended up training her.
fj12ryder
Platte City, MO
Posted: 01/05/19 03:07pm Link  |  Quote  |  Print  |  Notify Moderator
Those grease zerks won't really do much unless you put a whole lot of grease in there. Otherwise the grease will only do to lube the inner leg to the outer leg. A better way would be to remove the zerk, and spray some white lithium grease into the hole and onto the inner leg screw. That will actually do a little good, especially if you do the lower part of the leg where you stand a good chance of getting grease on the screw.
Howard and Peggy
"Don't Panic"
Super_Dave
Harrisville, UT
Posted: 01/05/19 03:46pm Link  |  Quote  |  Print  |  Notify Moderator
Mixing lubricant types can be a problem. Best to know what's already in there and stay with that.
Truck: 2006 Dodge 3500 Dually
Rig: 2018 Big Country 3155 RLK
Boat: 2003 Jetcraft 2125 - Yamaha 150 HP & 8 HP Kicker
fj12ryder
Platte City, MO
Posted: 01/05/19 03:51pm Link  |  Quote  |  Print  |  Notify Moderator
I can pretty much guarantee you that there isn't any grease to speak of on the screws. Any grease will be better than no grease. And it's very unlikely that you'll mix incompatible greases in this application.
Dave H M
IL
Posted: 01/09/19 07:50am Link  |  Quote  |  Print  |  Notify Moderator
On a landing gear. [emoticon] Mixing and matching or vise versa would be the least of my worries.
