RV.Net Open Roads Forum: The batch of missing threads from years ago?
Search only in Forum Posting Help and Support
Open Roads Forum  >  Forum Posting Help and Support
 > The batch of missing threads from years ago?
BobsYourUncle
Calgary Alberta Canada
Posted: 01/05/19 09:08pm Link  |  Quote  |  Print  |  Notify Moderator
Hey mods! Technical question for you...
I remember reading here and there over the past few years regarding a time when something burped on the forum servers and a whole lot of posts vanished somewhere into outer space, never to be seen or heard from again.
Could one of you kindly refresh my failing memory on what the time frame was when this happened?
Reason I ask is because for some reason, I decided to dig back on some of the stories / anecdotes I wrote about my RV (mis)adventures.
I found some using the search function. Can't believe some of the stuff I've written! "Gotta git me a tango" was one set of stories I found. Still laughing!....
I was specifically trying to find a thread I started that earned me the nickname of "Butter Boy" I had forgotten to turn my furnace off and a whole pound of butter would up on a heat register while driving down the road and melted into the duct. I think it was around 12 - 13.
Anyhow, can't find that thread and thought maybe it was part of the lost threads from yesteryear..
Thanks
Dmax/Allison
1997 Triple E Topaz 27' Bunkhouse TT
I do
Precision Guesswork
based on
Vague Assumptions
Unreliable Data of Dubious Accuracy
provided by persons of
Questionable Intellectual Capacity
Now, What would you like done?
pianotuna
Regina, SK, Canada
Posted: 01/05/19 09:43pm Link  |  Quote  |  Print  |  Notify Moderator
Hi Bob,
Try searching using google instead of the rather poor search on the forums.
Regards, Don
BobsYourUncle
Posted: 01/05/19 10:19pm Link  |  Quote  |  Print  |  Notify Moderator
Oh thanks Don. I didn't think about doing that.
I do, however, wonder if it will show up if its among the threads that vanished.
Guess I'll try and find out!
Dmax/Allison
I do
Precision Guesswork
based on
Vague Assumptions
BobsYourUncle
Posted: 01/05/19 10:39pm Link  |  Quote  |  Print  |  Notify Moderator
Gee Don, you're a genius!!
I found the thread I was looking for via Google. Same search parameters I used here to try to locate it.
Thanks. [emoticon]
Dmax/Allison
I do
Precision Guesswork
based on
Vague Assumptions
pianotuna
Regina, SK, Canada
Posted: 01/06/19 07:11am Link  |  Quote  |  Print  |  Notify Moderator
You would have figured it out Bob.
Regards, Don
BobsYourUncle
Posted: 01/06/19 08:37am Link  |  Quote  |  Print  |  Notify Moderator
[emoticon] yup!
Dmax/Allison
I do
Precision Guesswork
based on
Vague Assumptions
2oldman
Salton Sea
Posted: 01/06/19 09:01am Link  |  Quote  |  Print  |  Notify Moderator
Hard to believe this stuff is never fixed.
