RV.Net Open Roads Forum: Tech Issues: Honda EU2000i Generator Shop Notebook
 > Honda EU2000i Generator Shop Notebook
WesternHorizon
New Mexico
Posted: 01/06/19 09:02am Link  |  Quote  |  Print  |  Notify Moderator
The sticky "Honda 2000i Carb Job With Photos" has been very popular but apparently the photos are lost and can't be recovered.
I have started a shop notebook on the 2000i with a lot of quotes and links collected from all over the web.
It is all organized with a table of contents to help zero in on specific information you need.
A popular carb cleaning video has been reviewed second by second to clear up confusing sections and make the parts list more exact. I reviewed over 160 comments on this video to pull out the nuggets.
I also included a selection of photos as I watched the video and worked on the generator. All this is done on my workbench so details are not forgotten.
http://bit.ly/2R9l1f3
Hope this helps folks with the amazing EU2000i. Feedback welcome. Thank you.
* This post was edited 01/06/19 09:22am by WesternHorizon *
profdant139
Posted: 01/06/19 09:10am Link  |  Quote  |  Print  |  Notify Moderator
Thanks for posting this!!
Our trips -- pix and text
About our trailer
"A journey of a thousand miles begins with a single list."
RollandB
Albany, Or
Posted: 01/06/19 09:15am Link  |  Quote  |  Print  |  Notify Moderator
Wow, nice work! Saved it for future use.
2005 Silverado 3500 Crew Cab Long Box, Duramax/Allison, B&W Companion, TST507's
2016 Artic Fox 27-5L
OH48Lt
Whitehouse, OH
Posted: 01/06/19 09:21am Link  |  Quote  |  Print  |  Notify Moderator
Thanks, nice job. I now have it bookmarked in case I need it in the future.
2011 Ford F-150 Lariat Crew Cab 4x4 EcoBoost
2014 Cruiser RV Fun Finder 215WKS
2015 Harley Road Glide Special in Amber Whiskey
Yamaha Grizzly 660 (his)
Polaris Sportsman 500 H.O.(hers)
WesternHorizon
New Mexico
Posted: 01/06/19 09:37am Link  |  Quote  |  Print  |  Notify Moderator
Thanks all, happy to help
The section on how Burning Man takes care of the EU2000i is especially interesting.
They have apparently learned some tricks from the street vendor community (food trucks, etc.) that put huge hours on their machines.
2oldman
Salton Sea
Posted: 01/06/19 09:40am Link  |  Quote  |  Print  |  Notify Moderator
There's also a Carb job sticky here.
LittleBill
Scranton, PA USA
Posted: 01/06/19 10:42am Link  |  Quote  |  Print  |  Notify Moderator
the break in part is known, the comment right below burning man is a contradiction.
they say use 0w-20,
guy below has 6k hours and uses the cheapest 10-w30 he can find.
your mileage obviously varies.
firemedic1992
Edmonton, Alberta, Canada
Posted: 01/06/19 05:22pm Link  |  Quote  |  Print  |  Notify Moderator
Well done! Thank you!
theoldwizard1
SE MI
Posted: 01/07/19 06:38am Link  |  Quote  |  Print  |  Notify Moderator
A few tips on carburetor rebuild. These apply to all small engine carburetor rebuilds.
  • Use a flashlight an inspect the inside of the tank. If there is ANY debris inside the tank, remove it and rinse it clean ! Replace any fuel filter and consider replacing all fuel line.
  • One video says replace the bowl gasket (it usually looks like a flat rubber O-ring) every time. IMHO, this is not required. Do NOT get carburetor cleaner on the gasket as it will swell and will not fit properly
  • Get a very fine piece of stiff wire (a single bristle from a wire brush) and probe all holes/passageways to be sure there is no debris or varnish.
Lynnmor
Red Lion
Posted: 01/07/19 06:59am Link  |  Quote  |  Print  |  Notify Moderator
Do not use wire in jets, it will scratch and change the flow rate. If you must probe in those small holes, use a bristle from a paint brush.
