RV.Net Open Roads Forum: Travel Trailers: Solar panels
 > Solar panels
Oldpop55
Ca
Posted: 01/06/19 09:22am Link  |  Quote  |  Print  |  Notify Moderator
Looking at adding portable solar panels. Have a 2019 26 ft trailer, any ideas on how many watts i would need? And reliable brands.
pianotuna
Regina, SK, Canada
Posted: 01/06/19 10:13am Link  |  Quote  |  Print  |  Notify Moderator
Oldpop55,
Welcome to the forums.
Start with an energy audit. Or install 600 watts of panels with the Grape 40 amp controller. Portable is a poor solution, with storage being the number one issue, followed by having to strike and set them up, time after time after time.
Regards, Don
2oldman
Salton Sea
Posted: 01/06/19 10:33am Link  |  Quote  |  Print  |  Notify Moderator
Solar basics
azrving
Oatman
Posted: 01/06/19 12:47pm Link  |  Quote  |  Print  |  Notify Moderator
You need enough to replace what you are using plus roughly 10%
twodownzero
NM
Posted: 01/06/19 03:51pm Link  |  Quote  |  Print  |  Notify Moderator
How much was that for you? I'm about to install 400 watts on my rig to get started.
time2roll
Posted: 01/06/19 03:59pm Link  |  Quote  |  Print  |  Notify Moderator
400 watts is probably fine for most people. My 675 works fine on my 26' trailer.
Sometimes going big from the start is lower cost and better for ease of use.
A patchwork of small panels so that you eventually just barely have enough can turn solar into a multi year project that never really just works so you can mostly ignore the battery charge level.
675w Solar pictures back up
mike-uswest
Central Point, OR, USA
Posted: 01/06/19 04:13pm Link  |  Quote  |  Print  |  Notify Moderator
I have 360 watts of panels, Zamp 30 amp controller, and it works fine for me. I am careful to try getting the best solar exposure I can, don't waste power, and enjoy what you get. I'm not in Canada, so that can make a difference too though. I only have two 6 volt batteries though, I would like to up that but my 30 foot trailer runs out of room for all the toys.
Mike
2003 Dodge 2500 CTD, 4X4,
Arctic Fox 25Y
corvettekent
Marysville, WA
Posted: 01/06/19 04:16pm Link  |  Quote  |  Print  |  Notify Moderator
I like pianotuna's advice. I started with two 160 watt panels then added one more. I only have a 30 amp MPPT controller so it's now at it's limit. I wish I had 600 watts. Just double what you think you will need and you should be good.
2007.5 GMC Dually EC/LB, LMM. Banks IQ, Speed Brake, Six Gun. B&W Turnover Ball, Companion Hitch, Amp power steps. Hadley Air horns.
2004 32' Carriage 5th wheel. 480 watts of solar MPPT and four 6 volt batteries. Samlex 2,000 watt Pure Sine Wave Inverter.
pianotuna
Regina, SK, Canada
Posted: 01/06/19 05:27pm Link  |  Quote  |  Print  |  Notify Moderator
Hi,
I have 256 watts. It is fine for once a month trips of 4 to 5 days, or every weekend, but not nearly enough for full time.
twodownzero
NM
Posted: 01/06/19 06:07pm Link  |  Quote  |  Print  |  Notify Moderator
How many amp controller are you using? The kit that is being delivered tomorrow has a 40 amp kit. 400/12 = 33, so not much cushion there and the next biggest controller was pretty expensive.
 > Solar panels
