RV.Net Open Roads Forum: Can I use a WDH on a DP
 > Can I use a WDH on a DP
Page of 7
hotjag1
Lake Chelan, Wa/Lake Havasu, Az.
Posted: 01/06/19 03:31pm Link  |  Quote  |  Print  |  Notify Moderator
I tow a 22' enclosed trailer behind the DP in my signature. It has a 10,000 lb hitch with a 1000 lb tongue weight capacity.
I have been hauling a UTV weighing 1100 lbs in the front and a 3200 lb Suzuki Grand Vitara in the rear. I recently weighed the tongue with a scale(Sherline) and it weighed 1400 lbs...yikes!
The only loading option I have is putting the UTV in front and then load the Vitara backwards so that the engine is behind the axles. This reduced the tongue weight to 1200 lbs.
Is 200 lbs over the tongue rating a big No No, or do the manufacturers allow for a little overage? If not, how do I use a WDH on a DP?
It has ride height valves(always sits level)no matter how much weight is on the hitch, so how can I know if I am adjusting weight from rear to front of the DP?
There are people a lot more knowledgeable than me on here so I welcome any options or suggestions.
hotjag1
2003 40' Allegro Bus, 3 slides, 400hp 8.9 liter ISL Cummins
2000 24' Dynamax Isata
old guy
Oregon (pronounced Or e gun)
Posted: 01/06/19 03:49pm Link  |  Quote  |  Print  |  Notify Moderator
a wdh will increase you tongue weight capability. most hitches will have a tag on them telling you what the limit is with and without the wdh.
Chris Bryant
Arden, North Carolina
Posted: 01/06/19 03:53pm Link  |  Quote  |  Print  |  Notify Moderator
I would have a heavier hitch put on the DP, or have a certified welder look at beefing yours up.
-- Chris Bryant
My RV Service Blog
The RV.net Blog
Ivylog
Blairsville, GA and WPB, FL.
Posted: 01/06/19 04:06pm Link  |  Quote  |  Print  |  Notify Moderator
If you’re receiver is only fastened to a single cross tube I would be concerned but if the receiver continues forwards to a second cross tube forming a H, I would not worry about being over the 1000 lb rating.. Using WDH on a DP is not going to do much other than put more weight on your trailer tires.
08 HR Navigator 45'
Sold 04 Dynasty after 14 great years.
How I tow.
Towing a Prius without a dolly
How I spend the winter.
wildmanbaker
Kennewick, Washington
Posted: 01/06/19 04:13pm Link  |  Quote  |  Print  |  Notify Moderator
Check with you MH manufacturer about using a weight distribution hitch. You will get guesses and onions here, not the actual answer.
Wildmanbaker
ScottG
Bothell Wa.
Posted: 01/06/19 04:37pm Link  |  Quote  |  Print  |  Notify Moderator
You could use one but it isn't going to have any appreciable effect.
I would get what you have beefed up As Chris Bryant stated above.
Scott, Grace and Wesly
2018 Silver Fox 32A.
H0NDA eu2000i
down home
south
Posted: 01/06/19 04:41pm Link  |  Quote  |  Print  |  Notify Moderator
Might need a different trailer to get weight distributed over axles.
Not sure how the load looks on your trailer but sound like it is not centered over the axles. The total weigh you are hauling is not that great.
I'm not sure it would be in the cards or possible to move axles. If workable I would opt for heavier trailer or longer trailer with axles more forward required by your current trailer length configuration. Weight distribution needs to be different. imo
Big Katuna
Deland, FL
Posted: 01/06/19 04:59pm Link  |  Quote  |  Print  |  Notify Moderator
My 05 Fleetwood has a sticker on the hitch that says the hitch is rated for 500 pounds no WDH, 1000 pounds with.
If you get welding done disconnect the batteries and open all the breakers.
My Kharma ran over my Dogma.
ferndaleflyer
everywhere
Posted: 01/06/19 05:33pm Link  |  Quote  |  Print  |  Notify Moderator
Would you like some advice from experience? My partner has the same DP you have and tows a 30ft double stacker with a dragster, a door car, a golf cart, and lord only knows what else in there and no WDH. 10,000lb rated hitch. I myself have a 32 ft tri axel trailer with a door car and an ATV towing with a Monaco with a 10,000lb hitch and no problem. I have used this set up behind 2 other DPs as has my friend. I travel about 20,000mi a year and he may rack up more going to races here in the East. If your hitch is rated at 10,000 a little extra tongue weight won't do anything but help control the trailer....to little and it will wonder all over the road. Hope this helps
romore
Okanagan valley British Columbia
Posted: 01/06/19 08:18pm Link  |  Quote  |  Print  |  Notify Moderator
ONIONS?[emoticon] I would be more concerned with towing capacity, it sounds like no amount of weight distribution is going to bring him anywhere near it.
Page of 7
