RV.Net Open Roads Forum: Truck Campers: Slide problem
 > Slide problem
GeoBoy
Northeast
Posted: 01/07/19 05:29pm Link  |  Quote  |  Print  |  Notify Moderator
Harleybullet wrote:
ScottG What is a shear bolt, where is it and how do I get to it?
Dave
Do you have a Power Gear slide-out manual? If no download it and it will show you where the shear bolts are.
With the slide closed you will have to lay down on the floor of the camper and look up under the faceboard of the slide and look for the drive shaft. The bolt could be sheared or the shear bolt could have just loosened and dropped out.
One of my shear bolts dropped out and the other ones were loose. I reinstalled them with blue loctite and torqued to 14 foot pounds.
I removed the face board on my slide, then reinstalled it with fasteners hidden behind decorative caps, so it would be very easy to access the slide mechanism in the future, if need be.
Harleybullet
Holbrook, NY
Posted: 01/08/19 09:40am Link  |  Quote  |  Print  |  Notify Moderator
Will try on all suggestions will get back in a few days
Dave
Harleybullet
Holbrook, NY
Posted: 01/12/19 12:36pm Link  |  Quote  |  Print  |  Notify Moderator
Contacted Northwood Mfg and they suggested loosening 2 nuts on the front rail under the slide and putting in shims between the rail and the floor of the slide, 1/8" at a time to 1/2". Will try it soon I hope... right now it is freezing and windy in NY
GeoBoy
Northeast
Posted: 01/12/19 04:58pm Link  |  Quote  |  Print  |  Notify Moderator
Start with the shear bolts first, then make sure the timing of the slide is right on. Then there are other adjustments described in the page I referred you to.
* This post was edited 01/12/19 05:07pm by GeoBoy *
Hemi Joel
Minnesota
Posted: 01/13/19 01:12pm Link  |  Quote  |  Print  |  Notify Moderator
THis was a permanent solution on my 1150:
https://www.rv.net/forum/index.cfm/fuseaction/thread/tid/29723528.cfm
2018 Eagle Cap 1163 triple slide on a 93 Dodge D350 Cummins, DTT 89 torgue converter, big turbo, 3 extra main leafs, Rancho 9000s rear, Monroe gas magnums front, upper overloads removed, home made stableloads, bags.
54suds
adk mts.
Posted: 01/13/19 05:03pm Link  |  Quote  |  Print  |  Notify Moderator
clikey link
Harley being a ole hog man this should be a easy repair [emoticon]
2017 Chev ltz double cab,drw,4x/torklift tdn's,30k super hitch 36" extention
1999 Bigfoot 1011 & 2011 Jeep unlimited Rubicon toad
1988 Bigfoot c11
Harleybullet
Holbrook, NY
Posted: 01/14/19 07:22am Link  |  Quote  |  Print  |  Notify Moderator
Good to hear from you... hope all is well.... waiting for weather to break before I give this a try. PM you....thanks
Dave
 > Slide problem
