RV.Net Open Roads Forum: General RVing Issues: STORAGE PROBLEM
 > STORAGE PROBLEM
PLASTICMAN1
southern california
Posted: 01/06/19 05:45pm Link  |  Quote  |  Print  |  Notify Moderator
I have a industrial building with a 10' wide roll up door, would
a 34' class A motor home fit thru the door? has any body done it? It would be a straight shot.Haven't tried it yet! just asking!
thanks
gbopp
The Keystone State
Posted: 01/06/19 05:46pm Link  |  Quote  |  Print  |  Notify Moderator
How high is the door? The 10' width is tight but you can do it.
Measure the width of your rig with the mirrors folded or retracted.
Just Wandering 1
anywhere USA
Posted: 01/06/19 05:49pm Link  |  Quote  |  Print  |  Notify Moderator
width yes. height is the question.
PLASTICMAN1
southern california
Posted: 01/06/19 05:50pm Link  |  Quote  |  Print  |  Notify Moderator
ITS 14' HIGH
STBRetired
I-80 and I-55
Posted: 01/06/19 05:53pm Link  |  Quote  |  Print  |  Notify Moderator
Might need to fold in the mirrors but you will fit with a few inches to spare on each side.
1999 Newmar MACA 3796 F53 6.8L
2016 Ford Edge Sport
Roadmaster Sterling A/T with Brake Buddy Select
gbopp
The Keystone State
Posted: 01/06/19 06:01pm Link  |  Quote  |  Print  |  Notify Moderator
PLASTICMAN1 wrote:
ITS 14' HIGH
At 14' high you're good to go. Just watch the mirrors and go slow.
Measure the height of your RV just to make sure, You should not have a problem.
Death Valley!
Posted: 01/06/19 06:07pm Link  |  Quote  |  Print  |  Notify Moderator
At 14 feet you need to be “watching” all the time. Lord, give me 10 feet width minimum all the time and I will be happy.
2015 Winnebago 2101DS TT & Tahoe LTZ, 300 watts WindyNation solar-parallel & MPPT, Trojan T-125s. TALL flagpole for US flag. Prefer USFS, COE, BLM, NPS, TVA, USF&WS, state & county camps. Bicyclist! 14 year Army vet - 11B40 then 11A - old MOS 1542 & 1560.
blofgren
Surrey, B.C.
Posted: 01/06/19 06:47pm Link  |  Quote  |  Print  |  Notify Moderator
10’ is tight but doable. Just take your time and watch your mirrors as others have suggested. I have backed my RV’s into many storage buildings over the years and the inside of the building is very dark compared to outdoors so it is very helpful to have a spotter and a set of portable radios.
2013 Ram 3500 Megacab DRW Laramie 4x4, 6.7L Cummins, G56, 3.73, Maximum Steel, black lthr, RAM 20k sliding hitch, Retrax, Linex, and a bunch of options incl. cargo camera
rk911
Wheaton IL
PLASTICMAN1 wrote:
ITS 14' HIGH
ok.
- does the roll up door roll all the way past the upper frame of the door opening or dies it hang down a bit below the door opening?
- is there anything hanging from the ceiling that falls below the height of the opening?
- how deep is the building? will the RV fit inside with the dorr closed?
- how wide is the building interior? will you be able to get out of the RV and exit the building?
'73,
rich, n9dko
Every retired man needs three things....a good truck, a good dog and a working wife
2016 Itasca Suncruiser 38Q
'46 Willys CJ2A
'03 Jeep Wrangler TJ
'10 Jeep Liberty KK
fairway2002
Michigan
Posted: 01/06/19 08:04pm Link  |  Quote  |  Print  |  Notify Moderator
Yes it will. I do it 30 times a year.. It's tight. Hard part of going in a building is its like a black hole until your mirrors are in. I have under an inch on each side with the weather stripping
Go slow
 > STORAGE PROBLEM
