RV.Net Open Roads Forum: General RVing Issues: STORAGE PROBLEM
 > STORAGE PROBLEM
mountainkowboy
Socal > NE Oregon
Posted: 01/06/19 11:01pm Link  |  Quote  |  Print  |  Notify Moderator
Shouldn't be an issue after you do it a few times.
I used to back this
Down this all the time, with about 2" to spare on each side.
Chuck & Ruth with 4-legged Molly
1990 F350 S/C Lariat Dually (Red)
1990 S&S 11SC Cabover
2011 Ford Ranger
1987 HD FLHTP
SidecarFlip
SE Michigan
Posted: 01/07/19 07:26am Link  |  Quote  |  Print  |  Notify Moderator
Jam it and hope fr the best....lol
2015 Backpack SS1500
1997 Ford 7.3 OBS 4x4 CC LB
schlep1967
Harrisburg, PA
Posted: 01/07/19 09:49am Link  |  Quote  |  Print  |  Notify Moderator
Tape Measure.....
2008 Dodge Ram 2500 Diesel
2009 Open Range 385RLS
Pull-Rite Super Glide
wanderingbob
monticeeo, fla
Posted: 01/07/19 12:51pm Link  |  Quote  |  Print  |  Notify Moderator
Be sure that your slides are in !
Campinfan
Washtenaw County, Michigan
Posted: 01/09/19 10:58am Link  |  Quote  |  Print  |  Notify Moderator
Back up until it sounds expensive. Go slow and good luck. Must be nice to have an indoor space. Enjoy it.
______________________
2016 F 350 FX4 4WD,Lariat, 6.7 Diesel
41' 2018 Sandpiper 369 SAQB
Lovely wife and three children
Jebby14
Windsor Ontario
Posted: 01/09/19 12:03pm Link  |  Quote  |  Print  |  Notify Moderator
if in 1st you don't succeed then shift to 2nd and gas it.........
If it moves and it shouldn't..... duct tape
if it doesn't move and it should.....WD40
if all else fails .....BFH
Wherever I happen to park
Posted: 01/09/19 04:29pm Link  |  Quote  |  Print  |  Notify Moderator
I agree the RV is 8 1/2 foot wide save for the mirrors might go out to 9 or a bit more. Should be no problem with a 10 foot wide door.. BUT HEIGHT... That's the issue
True story: The Michigan state police give a Trooper a Safe Driving award if he goes long enough without denting anything.. I was reading the news on the award.
The contestant While exiting the Headquarters Garage. Did strike the HEADER of the door And POOF went his award eligibility for another 4 years. (paraphrased).
We figured out how he did it.. Can you guess? (and no he did not pull a wheelie).
Home is where I park it.
bucky
Raleigh metro
Posted: 01/10/19 03:50am Link  |  Quote  |  Print  |  Notify Moderator
Leave enough room on the side with the door so that you can get out 0f the RV.
I think that I would pull in nose first. It's easier to back into daylight than a black hole. It would also minimize exhaust fumes.
2005 Cummins 2500 2WD LB quad cab pulling a 2007 Jayco 345bhs. It pulls better than Marcell Ledbetter's mule.
mowermech
Billings, MT
Posted: 01/10/19 09:14am Link  |  Quote  |  Print  |  Notify Moderator
Verify that your television antenna is down.
CM1, USN (RET)
Daily Driver: '06 PT Cruiser Turbo
Toad: '05 Wrangler Unlimited
Toy: 1999 Dodge QC LWB, Cummins, Auto, 4X4
Other toys: 2 Kawasaki Brute Force 750 ATVs.
Deb and Ed M
SW MI & Space Coast, FL USA
Posted: 01/10/19 09:34am Link  |  Quote  |  Print  |  Notify Moderator
I used to BACK our 28' Class C (widebody) through a 10' door all the time (and the driveway was downhill and twisty). I would back up until the mirrors almost touched the door frame; then I'd fold them in. Once clear of the door frame, I'd open the driver's side mirror again, and finish backing in. Yes, it's hard to see inside the building compared to the bright outdoors light, so I added reflectors on the driver's side polebarn posts at the right height to be illuminated by the taillights. You just need to be patient is all.
 > STORAGE PROBLEM
