RV.Net Open Roads Forum: Fifth-Wheels: Morryde pinbox
 > Morryde pinbox
farmerrob
duncan, sc
Posted: 01/07/19 03:33pm Link  |  Quote  |  Print  |  Notify Moderator
Our Cougar 27RKS weighs less than 9000 pounds and the ride ts not real bad and I have found a Moryde pinbox for $455. Will the ride be that much better?
This question has probably been asked and answered many times but I am asking for other Cougar 27RKS owners if they have anything to say or add.
My tv is a 2018 chev 2500 duramax which carries this 5th wheel very well.
2018 chevy 2500 sb dc duramax
2018 cougar 27rks
B&W hitch
Goodyear endurance
dmck413
Fluvanna Va
Posted: 01/07/19 03:38pm Link  |  Quote  |  Print  |  Notify Moderator
I put an air ride pin box on ours and it was a huge improvement
edbehnke
North America (from Michigan)
Posted: 01/07/19 04:10pm Link  |  Quote  |  Print  |  Notify Moderator
probably won't change anything.
eddie and sandie
3402 Montana 2013
2500HD
B.O. Plenty
Minnesota
Posted: 01/07/19 04:24pm Link  |  Quote  |  Print  |  Notify Moderator
The Moryde pin box is designed to cushion chucking which is the push pull action felt going down the road. If this isn't much of a problem, then it probably won't do much.
B.O.
Former Ram/Cummins owner
2015 Silverado 3500 D/A DRW
Yup I'm a fanboy!
2016 Cedar Creek 36CKTS
goducks10
There
Posted: 01/07/19 05:13pm Link  |  Quote  |  Print  |  Notify Moderator
I put one on my 5er 5 years ago. It cured some of the chucking. Even MR says it's not a cure all. I can see that it's working from the dust mark spots on the pin plate. Would I buy another? Probably not. I think I'd spend the extra money and go with a Reese Goose Box. A lot more than $455. I'll stick with what I have as for the most part it's good enough. Not worth losing money selling the MR then forking out $1135.79.
Cummins12V98
on the road
Posted: 01/07/19 08:08pm Link  |  Quote  |  Print  |  Notify Moderator
All depends on the hitch you have. CURT is known to cause CHUCKING. Pin box won’t cure that.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
Retired JSO
Northeast Florida
Posted: 01/07/19 09:40pm Link  |  Quote  |  Print  |  Notify Moderator
We are on our second fifth wheel both with the morryde rubber pin box. The first fiver, a 2004 Sandpiper bought new with a standard box was a chucking bucking horse, first with a Reese Slider 2006, F250, then a 2007 F350 DRW with a B&W companion was a bucking fool. After the Morryde install, we had a much smother ride. It didn’t remove all the chucking but made it more comfortable. Our new Cardinal came with the Morryde box, steps and cushion equalizer system. Have hot had chucking/bucking in our recent tows.
* This post was edited 01/07/19 09:55pm by Retired JSO *
ACZL
UPstate,NY
Posted: 01/08/19 02:12am Link  |  Quote  |  Print  |  Notify Moderator
Can't help you with the MR question, but have had the 5th Airborne on 2 different trailers and have been extremely happy w/ them.. FWIW, 1st hitch in truck was a Reese 16k then upgraded to a B&W 18k Patriot. The Reese was good but in no way in same class as the B&W and I really think the combo of the 2 (B&W and 5th AB) compliment each other.
2017 F350 DRW XLT, CC, 4x4, 6.7
2018 Big Country 3560 SS
"The best part of RVing and Snowmobiling is spending time with family and friends"
"Catin' in the Winter"
RollandB
Albany, Or
Posted: 01/08/19 08:26am Link  |  Quote  |  Print  |  Notify Moderator
I had an older Husky manual sliding hitch, changed a 13,000# Komfort 5er from an all steel pinbox to the MorRyde rubber pin box and noticed a better ride. Not perfect, but less chucking. The best improvement on the same TV and 5er was when I replaced the old Husky with a new Pullrite Superglide.
2005 Silverado 3500 Crew Cab Long Box, Duramax/Allison, B&W Companion, TST507's
2016 Artic Fox 27-5L
GHop
California
Posted: 01/08/19 09:57am Link  |  Quote  |  Print  |  Notify Moderator
I have the MorRyde pin box and as stated before, it does help with "Chucking". The question I have what do you mean, "help with the ride?" Can you give a little more description of the problem we can give you better options to consider? To help with broken plates and open cabinets, I'm installing the MorRyde suspension 4000 system as an upgrade.
 > Morryde pinbox
