RV.Net Open Roads Forum: Fifth-Wheels: DC power low message on fridge
 > DC power low message on fridge
RDalr
St-Zotique
Posted: 01/07/19 04:20pm Link  |  Quote  |  Print  |  Notify Moderator
Hi,
I have a message on my fridge that says DC power low. Can someone give me a clue as to its meaning, and what do I need to do to address the issue.
Your help is appreciated.
Rick
RDalr
bob213
Fresno, CA
Posted: 01/07/19 04:35pm Link  |  Quote  |  Print  |  Notify Moderator
Sounds like your battery is low. If you are plugged in to 110v then your converter is not charging battery. Refrig. needs 12v for control board no matter how it's running.
2oldman
Salton Sea
Posted: 01/07/19 04:41pm Link  |  Quote  |  Print  |  Notify Moderator
Get out your voltmeter and measure your 12vdc voltage.. anywhere.
RDalr
St-Zotique
Posted: 01/07/19 04:50pm Link  |  Quote  |  Print  |  Notify Moderator
Yesterday, my battery was showing 13.3 volts, today it is down to 12.02 volts. It looks like my power supply unit stopped charging the battery. I will double check my connections. I may charge my battery also.
Thank you for the replies.
enblethen
Moses Lake, WA
Posted: 01/07/19 05:36pm Link  |  Quote  |  Print  |  Notify Moderator
It could be failing battery. Converter could be putting proper voltage out but battery shorted.
I would take battery out or at least disconnect it, then charge it up. Wait overnight for battery to stabilize. If it goes flat, replace the battery.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
Charlie D.
E. Texas-Orange
Posted: 01/08/19 08:04am Link  |  Quote  |  Print  |  Notify Moderator
I don't understand comments about it being a low battery. My battery went dead because I forgot to turn the breaker on after connecting to shore 3 months ago. I will be getting a new battery today. The 50 amp power has been on for 2 weeks and everything functions without a battery which I removed 3 days ago.. Fridge was turned on Sunday and has been on normal temps since then.
Enjoying Your Freedom?
Thank A Veteran
Native Texan
2013 Prime Time Crusader 330MKS
2018 Chevy 2500 D/A Z71 4x4 Offroad
2006 Holiday Rambler Savoy 33SKT-40,000 trouble free miles-retired
2006 Chevy 2500 D/A-retired
2013 Chevy 2500 D/A-retired
2oldman
Salton Sea
Posted: 01/08/19 08:12am Link  |  Quote  |  Print  |  Notify Moderator
If he's not on shore power it is.
Super_Dave
Harrisville, UT
Posted: 01/08/19 08:47am Link  |  Quote  |  Print  |  Notify Moderator
Referencing Bob213's comment about no matter how the frig is being powered.
Truck: 2006 Dodge 3500 Dually
Rig: 2018 Big Country 3155 RLK
Boat: 2003 Jetcraft 2125 - Yamaha 150 HP & 8 HP Kicker
RDalr
St-Zotique
Posted: 01/09/19 03:11pm Link  |  Quote  |  Print  |  Notify Moderator
If I disconnect my battery, the fridge does not work on both electric and/or gas.
I charged the battery 2 days ago. It was reading 13 volts. Since then, the battery is going down daily. How do I determine if my power supply is charging the battery?
2oldman
Salton Sea
Posted: 01/09/19 03:54pm Link  |  Quote  |  Print  |  Notify Moderator
Voltmeter
