RV.Net Open Roads Forum: Fifth-Wheels: DC power low message on fridge
 > DC power low message on fridge
enblethen
Moses Lake, WA
Posted: 01/09/19 03:55pm Link  |  Quote  |  Print  |  Notify Moderator
Be good to now what kind of rig plus make and model!
Normally I would disconnect the battery, then connect voltmeter across leads coming from the converter, check voltage, record it, then disconnect the rig from shore power, voltage should go away.
Voltage should be over 13 volts when connected to shore power.
I would locate your converter and provide make and model.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
time2roll
Posted: 01/09/19 04:48pm Link  |  Quote  |  Print  |  Notify Moderator
RDalr wrote:
Yesterday, my battery was showing 13.3 volts, today it is down to 12.02 volts.
Not sure where the low trigger is for the indicator but fridge should run fine down to 10 volts.
Are you measuring the house battery or the chassis battery? Yes 13.2+ volts would be the normal when plugged in.
675w Solar pictures back up
RDalr
St-Zotique
Posted: 01/09/19 07:12pm Link  |  Quote  |  Print  |  Notify Moderator
2oldman, could you be more specific? I.e. what voltage should I be looking for if in either cases? Etc.. thanks
RDalr
2oldman
Salton Sea
Posted: 01/09/19 09:52pm Link  |  Quote  |  Print  |  Notify Moderator
Enblethen pretty much covered it.
RDalr
St-Zotique
Posted: 01/10/19 07:41am Link  |  Quote  |  Print  |  Notify Moderator
Thank you for the added information.
neal10a
Madison CT
Posted: 01/10/19 06:17pm Link  |  Quote  |  Print  |  Notify Moderator
Check the circuit breaker between the converter and battery. Many have a manual CB with manual reset. However, in many trailers with a three stage converter will maintain the fridge at 13+ volts if the CB to the battery has tripped. So not knowing your trailer model or make or wiring configuration it is difficult to help you. A 3 stage converter in bulk charge will put out 14+ volts and absobtion charge will be 13.5 and float charge (fully charged ) will be 13.2v.
RDalr
St-Zotique
Posted: 01/11/19 07:08am Link  |  Quote  |  Print  |  Notify Moderator
My converter has blown both 30 amps fuses and it no longer converts 110 volt to 12 volt DC current. I ordered a replacement. Thank you all for your suggestions.
bob213
Fresno, CA
Posted: 01/11/19 09:34pm Link  |  Quote  |  Print  |  Notify Moderator
Super_Dave wrote:
2oldman wrote:
Charlie D. wrote:
I don't understand comments about it being a low battery.
If he's not on shore power it is.
Referencing Bob213's comment about no matter how the frig is being powered.
I believe when on shore power you need a functioning converter to supply 12v to the control board even without a battery. I could be wrong but I think the control boards are 12v.
enblethen
Moses Lake, WA
Posted: 01/11/19 09:41pm Link  |  Quote  |  Print  |  Notify Moderator
I would check your battery to make sure it is connected correctly.
The negative should go to the frame of the rig.
Would you post make and model of your current converter?
time2roll
Posted: 01/11/19 10:20pm Link  |  Quote  |  Print  |  Notify Moderator
While you wait... have the battery checked.
