RV.Net Open Roads Forum: Class C Motorhomes: Replacing countertop with Corian (solid surface)
 > Replacing countertop with Corian (solid surface)
BruceMc
Oregon - Willamette Valley
Posted: 01/07/19 11:25pm Link  |  Quote  |  Print  |  Notify Moderator
New years project: Replacing MDF (WasWood) countertop with Corian (aka Solid Surface) material, including a new sink. We needed more counter space and less sink, as the original round/deep sink was nice, we had very little counter space. After getting a couple bubbles in the was-wood, we decided to go to the effort to replace the countertop, the dinette table and bath counter with solid surface material:
Plan:
I'll post more as I complete the project, however, you can see the progress starting with image Gluing the counter top.
* This post was last edited 01/26/19 09:14am by BruceMc *   View edit history
'16 Forest River Sunseeker 2250SLEC Chevrolet 6.0L
Previously:
'00 Four Winds 26Q Class C (Ford E350 V10)
'96 Kit Sportsmaster 212f Fifth Wheel/'93 GMC Sierra K2500
'91 SunLite poptop truck camper
and the first: a Wildernest flip-top canopy.
theoldwizard1
SE MI
Posted: 01/08/19 10:22am Link  |  Quote  |  Print  |  Notify Moderator
All "man made" solid surfaces are quite durable, but they can crack from extreme heat or flexing of the substructure.
ron.dittmer
North-East Illinois
Posted: 01/08/19 01:36pm Link  |  Quote  |  Print  |  Notify Moderator
Our rig SEEN HERE has Corian counter tops as shown in some of the pictures, but the material is only a 1/2" thick. We never had a problem with it, and nobody on the Phoenix forum has either....that I know of. Our stove top and sink are both surrounded by Corian. It has been a very good material.
Nice work there BruceMc, but I would surely miss having a bigger sink. I know, I know, it's all about trade-offs. [emoticon]
2007 Phoenix Cruiser model 2350, with 2006 Jeep Liberty in-tow
theoldwizard1
SE MI
Posted: 01/08/19 04:09pm Link  |  Quote  |  Print  |  Notify Moderator
1/2" is "standard" for Corian. They typically double up the front face to make it look thicker.
I have a friend who cracked her Corian TWICE ! They upgraded her to 3/4" which is considered "commercial".
BruceMc
Posted: 01/08/19 07:29pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks Ron!
Regarding the cracks, it probably depends on the size of the panel, how it is mounted and supported, and if there are any odd binding pressures. The material must be treated like glass - if there's a chip in the edge, a crack can run just like it does in glass.
The material I'm using is 1/2", or more correctly, 12mm. I added 1/4" shims to the tops of the cabinet to bring the top up to the same height as the original in order for the stove to fit w/o modifications.
As it's 1/2", I built up the edges to create 1" / 24mm around the perimeter using contrasting material:
We've never needed a large sink in our campers/motorhomes. I put a small pan or bowl in the bottom of the big round sink, fill it with a pint or so of hot water and soap. Then as I wash dishes, I rinse them with a small stream of hot from the faucet, which sometimes runs back into the pan/bowl. My wife takes the rinsed item & drys it, then puts it back where it belongs.
I guess this is due to my sailing days where I learned to conserve water, and the early camping days where we would consume only 5 to 10 gallons of potable water over a week for a family of five. We used local stream or lake water for dish washing and baths.
D.E.Bishop
Eagle Rock, CA
Posted: 01/08/19 07:56pm Link  |  Quote  |  Print  |  Notify Moderator
I think you are doing a great job but I am sure for every 100,000 successful uses of 1/2" solid surface material there are two or three unsuccessful uses of anything you wish to consider at any thickness. Nice Job and don't worry about the naysayers.
"I travel not to go anywhere, but to go. I travel for travel's sake. The great affair is to go". R. L. Stevenson
David Bishop
2002 Winnebago Adventurer 32V
Back to a 2006 Suzi GV
Roadmaster 5000
Roadmaster backplates
BruceMc
Posted: 01/08/19 07:57pm Link  |  Quote  |  Print  |  Notify Moderator
D.E.Bishop, thanks! I'm certainly not concerned of cracks, or I'd have found a different material. I've done formica counter tops, but had never liked the results. This gave me an opportunity to try a medium I'd never used before so I thought I'd try my hand at Corian.
Our main issue with the setup in our Sunseeker was the dismal lack of counter space due to the large sink: (sink removed in this image; I was resealing the area due to the water leak which caused the bubbles & spongy spots)
BruceMc
Posted: 01/09/19 08:26pm Link  |  Quote  |  Print  |  Notify Moderator
I finished the backsplash trim today:
Installed:
Corner detail:
Right side with metal tile held in place; this is the material I'll install beside/behind the stove tomorrow:
T18skyguy
Eugene, OR
Posted: 01/09/19 09:52pm Link  |  Quote  |  Print  |  Notify Moderator
Beautiful work Bruce. Thats a nice winter project since it's raining all the time here. I'm in the valley too. Thanks for sharing.
Retired Anesthetist. LTP. Pilot with mechanic/inspection ratings. 2017 Jayco Greyhawk 31FS. Wife and daughter. Three cats which we must obey.
BruceMc
Posted: 01/19/19 07:50pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks T18SkyGuy!
The story continues On Forest River Forums ...
