RV.Net Open Roads Forum: Class A Motorhomes: Swinger
randysan
Pennsylvania
Posted: 01/08/19 06:51am Link  |  Quote  |  Print  |  Notify Moderator
I am looking to buy my first RV, and this one looks interesting. (Yes this is my budget)
Anyone have anything good bad or otherwise to say about this vehicle?
Seems like a nice vehicle for the price
....I appreciate any input as I am a literal newbie.
thanks!
R
https://www.facebook.com/marketplace/item/1958345247801074?surface=product_details
gbopp
The Keystone State
Posted: 01/08/19 07:11am Link  |  Quote  |  Print  |  Notify Moderator
Clicky
The Swinger looks clean and in good condition.
Check for any roof leaks, stains etc.. A small leak can ruin the vehicle if not repaired fairly quickly.
A big thing is the tires. Check the age from the date code on the side of the tire.
RV tires usually age out before they wear out. Don't go just by tread depth.
Most RVers replace their tires between 6-10 years.
If you're not familiar with recreational vehicles, consider hiring a mobile RV tech to inspect the unit before you give the seller any money or sign any agreements. It will be a couple hundred dollars well spent.
Make sure everything works before buying any RV.
* This post was edited 01/08/19 07:17am by gbopp *
randysan
Pennsylvania
Posted: 01/08/19 07:40am Link  |  Quote  |  Print  |  Notify Moderator
thanks g, that's good advice!
T18skyguy
Eugene, OR
Posted: 01/08/19 09:09am Link  |  Quote  |  Print  |  Notify Moderator
Before you buy it,make sure you listen to the engine stone cold. Those 460's are notorious for leaking manifolds. If you hear a steady click click click when starting cold that means warped manifold and you'll need headers. I use to have two of them.
Retired Anesthetist. LTP. Pilot with mechanic/inspection ratings. 2017 Jayco Greyhawk 31FS. Wife and daughter. Three cats which we must obey.
randysan
Pennsylvania
Posted: 01/08/19 10:32am Link  |  Quote  |  Print  |  Notify Moderator
OK, good advice....i will def do a cold engine listen.
thank u!!
185EZ
Infinity and Beyond
Posted: 01/08/19 11:36am Link  |  Quote  |  Print  |  Notify Moderator
I first read the title and thought this thread is going to be fun,lol
edit;
different rv
* This post was edited 01/08/19 02:27pm by 185EZ *
garyemunson
Reno, Nevada
Posted: 01/08/19 01:26pm Link  |  Quote  |  Print  |  Notify Moderator
Looks nice...be aware that even though 10K seems like a good price, reselling it will be difficult without a slide. Most RV buyers won't consider a unit without a slide.
edbehnke
North America (from Michigan)
Posted: 01/08/19 01:47pm Link  |  Quote  |  Print  |  Notify Moderator
get it then you will be a real swinger.
eddie and sandie
3402 Montana 2013
2500HD
randysan
Pennsylvania
Posted: 01/08/19 01:50pm Link  |  Quote  |  Print  |  Notify Moderator
thanks gary....and, --i of course don't know what i'm talking about, but it's hard to believe that most RV buyers only consider vehicles with slides.
randysan
Pennsylvania
Posted: 01/08/19 01:54pm Link  |  Quote  |  Print  |  Notify Moderator
hah!--but once can't swing without slides [emoticon]
