RV.Net Open Roads Forum: Tech Issues: Adding two 6v to two 12v?
 > Adding two 6v to two 12v?
judelaurenzo25g
Downey, CA
Posted: 01/08/19 12:16pm Link  |  Quote  |  Print  |  Notify Moderator
Hi All,
We just moved from a 5th wheel toy hauler to a new class A motorhome. I'm not sure if I should do another set of 12's or add 6's in series. In an ideal world I would swap out all to 6v's but that's not an option. What are you thoughts on this?
Thanks,
JL25g
A ship in harbour is safe, but that is not what ships are built for.
Ex-Tech
West
Posted: 01/08/19 12:25pm Link  |  Quote  |  Print  |  Notify Moderator
Absolutely the six volt!
donn0128
Pronounced Ore-gun
Posted: 01/08/19 12:27pm Link  |  Quote  |  Print  |  Notify Moderator
6Vs are a bit taller. Can you actually fit them in? Does your camping style actually need 6V batteries?
* This post was edited 01/08/19 12:39pm by donn0128 *
Crestview area, Inyo County, California
Posted: 01/08/19 12:31pm Link  |  Quote  |  Print  |  Notify Moderator
I don't like mixing batteries with different ages, volts or AHs. As Don said, measure carefully before buying.
2015 Winnebago 2101DS TT & Tahoe LTZ, 300 watts WindyNation solar-parallel & MPPT, Trojan T-125s. TALL flagpole for US flag. Prefer USFS, COE, BLM, NPS, TVA, USF&WS, state & county camps. Bicyclist! 14 year Army vet - 11B40 then 11A - old MOS 1542 & 1560.
BFL13
Victoria, BC
Posted: 01/08/19 12:47pm Link  |  Quote  |  Print  |  Notify Moderator
I have banked a pair of 6s with a pair of 12s in some of my set-ups, with no problems. Main thing is that the 12s and 6s need to be in similar "condition" so one pair does not ruin the other pair if banked for a long period.
If the new MH's 12s are older, IMO consider them to be not right for matching with a new pair of any type of battery. Or you can get a pair of used Interstate Econo Power 12s for half price of new ones, and bank the four until they are all run down, and then buy four new batteries of whichever type you prefer.
In all cases where physically possible, put the load and charging wires across the whole bank of four. Try not to have a "downstream" pair or individual battery.
1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
See Profile for House electronics set-up.
2oldman
New Mexico
Posted: 01/08/19 12:49pm Link  |  Quote  |  Print  |  Notify Moderator
Discussions about 1 12v battery: (pretty close to what you're doing)
Add 12v to 2 6v
12 and 2 6v 2010
judelaurenzo25g
Downey, CA
Posted: 01/08/19 12:59pm Link  |  Quote  |  Print  |  Notify Moderator
6's will fit, I am moving my battery bank to the empty storage compartment next to my stairs (where they are located now). I could probably fit 10 batteries in that compartment if I wanted too, but weight would be a problem. I will add a few vents to the compartment to let gasses out.
judelaurenzo25g
Downey, CA
Posted: 01/08/19 01:03pm Link  |  Quote  |  Print  |  Notify Moderator
Add 12v to 2 6v
12 and 2 6v 2010
Thanks! I did search but didn't use the proper terms I guess.
edbehnke
North America (from Michigan)
Posted: 01/08/19 01:42pm Link  |  Quote  |  Print  |  Notify Moderator
remeber batteries always go to the weakest battery. heck, just replace them all.
eddie and sandie
3402 Montana 2013
2500HD
judelaurenzo25g
Downey, CA
Posted: 01/08/19 02:51pm Link  |  Quote  |  Print  |  Notify Moderator
the 2 - 12's are new. It would be a waste.
