RV.Net Open Roads Forum: Tech Issues: Adding two 6v to two 12v?
 > Adding two 6v to two 12v?
time2roll
Posted: 01/09/19 10:08am Link  |  Quote  |  Print  |  Notify Moderator
You can spring for a new Class A but putting a matching set of batteries is not feasible?
675w Solar pictures back up
Wherever I happen to park
Posted: 01/09/19 04:22pm Link  |  Quote  |  Print  |  Notify Moderator
Well I was being a bit "Sarcastic" with the word "Slight" I agree double the usable capacity is a BIG difference.
Also in the 9 years my Original Interstate GC-2's lasted I "OOPSED" a few times. what is an OOPS. Down so far even ther light won't light. Most of those were Early on. and the Replacement Deka' been OOPSED one time but that was not my fault. (Converter died).
MARINE/deep cycler and Starting batteries generally do not recover well from that kind of a VERY DEEP discharge.
Home is where I park it.
RJsfishin
Winston Or.
Posted: 01/09/19 05:36pm Link  |  Quote  |  Print  |  Notify Moderator
I don't know what you're expecting to gain from 2 6v over 2 12v, both being deep cycle. And BTW, 12v RV marine / trolling motor batteries are deep cycle batteries, despite what "know it alls" lead you to believe.
Buy 2 new 12v batteries same as the existing 2, and you will be happy.
You will not notice any difference if you go to 6v, if you discharge to 50%
Rich
'01 31' Rexall Vision, Generac 5.5k, 1000 watt Honda, PD 9245 conv, 300 watts Solar, 150 watt inv, 2 Cos 6v batts, ammeters, led voltmeters all over the place, KD/sat, 2 Oly Cat heaters w/ ox, and towing a 2012 Liberty, Lowe bass boat, or a Kawi Mule.
Posted: 01/10/19 07:47am Link  |  Quote  |  Print  |  Notify Moderator
Well I did not afford my Class A by throwing out perfectly good stuff (Wasting money) and I know for a fact that so long as they are in Parallel not series. batteries need only match on one parameter VOLTAGE. Batteries will work out all the other differences. You can parallel a aaa aaaa c and D battery and they will work it out.
Same with a Group 24 27. 29 31 and a pair of GC2. they will work it out. 100% guaranteed.
3 tons
CA.
Posted: 01/10/19 06:27pm Link  |  Quote  |  Print  |  Notify Moderator
Not trying to be one of those nasty ‘Know-it-alls” but one should be advised that not all 12v as advertised ‘deep cycle’ batteries are truly deep cycle, many are actually hybrid designs to allow for boat engine cranking...A true deep cycle can cycle below a 50% state of charge without long term damage...
3 tons
pianotuna
Regina, SK, Canada
Posted: 01/10/19 09:14pm Link  |  Quote  |  Print  |  Notify Moderator
Here is the best resource for connecting batteries in parallel.
http://www.smartgauge.co.uk/batt_con.html
Regards, Don
judelaurenzo25g
Downey, CA
Posted: 01/11/19 12:54am Link  |  Quote  |  Print  |  Notify Moderator
If you read the whole post you would have seen that money isn't the issue. I just didn't want toss out two new 12v. I am adding two more batteries so I would have a total of 4. I was trying to figure out if adding two 6 would work with the 12v ok.
A ship in harbour is safe, but that is not what ships are built for.
judelaurenzo25g
Downey, CA
Posted: 01/11/19 12:56am Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the advice, I was leaning this way and decided to do exactly what you're suggesting.
judelaurenzo25g
Downey, CA
Posted: 01/11/19 12:59am Link  |  Quote  |  Print  |  Notify Moderator
I'm not cheap but I'm trying to follow your lead and not throw money away. I've done lots of that in my younger days.
