RV.Net Open Roads Forum: Tech Issues: 2000' Onan 4000 Microquite generator replacement
 > 2000' Onan 4000 Microquite generator replacement
Lakeplay
64063
Posted: 01/08/19 02:53pm Link  |  Quote  |  Print  |  Notify Moderator
Has anyone replaced their old generator with something newer? Mine bit the dust and while researching, I've been seeing a lot of issues with this model. I don't want to spend the money fixing this one if its problematic. Besides, its 18 years old. Ideally I would like to remove the one I have and install something newer in the same place.
pianotuna
Regina, SK, Canada
Posted: 01/08/19 05:38pm Link  |  Quote  |  Print  |  Notify Moderator
I hope you have deep pockets.
I would replace it with a Champion 3400 inverter generator with remote electric start.
Regards, Don
A Good Cigar
Avondale, AZ
Posted: 01/08/19 06:03pm Link  |  Quote  |  Print  |  Notify Moderator
How did the old generator bite the dust? How many hours are on it?
2000 Itasca Suncruiser 35U
twodownzero
NM
Posted: 01/08/19 07:08pm Link  |  Quote  |  Print  |  Notify Moderator
Can I have your generator that bit the dust? I can't imagine it'd cost anything even close to what a new one costs to fix it.
Lakeplay
64063
Posted: 01/08/19 08:05pm Link  |  Quote  |  Print  |  Notify Moderator
Tech told me it has internal issues. Backfires, white smoke. Only 220 hours.
Lakeplay
64063
Posted: 01/08/19 08:07pm Link  |  Quote  |  Print  |  Notify Moderator
Used one from junk yard is 2k.
Lakeplay
64063
Posted: 01/08/19 08:21pm Link  |  Quote  |  Print  |  Notify Moderator
I would replace it with a Champion 3400 Champion 3400 inverter generator with remote electric start.
Thanks. Would it overhead being placed in the same compartment?
pianotuna
Regina, SK, Canada
Posted: 01/08/19 10:27pm Link  |  Quote  |  Print  |  Notify Moderator
Use part of the output to power a cooling fan. The fan needs to be 12 volt similar to the thermostatically controlled ones for radiators.
A Good Cigar
Avondale, AZ
Posted: 01/09/19 01:20am Link  |  Quote  |  Print  |  Notify Moderator
I say get a better tech! Did he specify what the problem was? I'm guessing that he didn't
It is almost impossible to destroy an Onan after only 220 hours!! Onans have a built in low oil pressure switch to protect the engine, and oil pressure is just about the ONLY thing that could cause "internal issues" in a engine with so few hours! I am no expert by any means, but it is certainly worth your peace of mind and usefulness of your RV to have that generator looked at by a competent tech! More than likely, it'll be the usual problem of a gummed up carb, or a bad control board, both ~$500 repairs!
Good luck[emoticon]
Lakeplay
64063
Posted: 01/09/19 06:25am Link  |  Quote  |  Print  |  Notify Moderator
Good luck[emoticon]
Its actually been looked at by 2 tech's. One was a ONAN tech who told me it had to come out and would cost a minimum of 1k.
