RV.Net Open Roads Forum: Travel Trailers: single axel or double
Open Roads Forum  >  Travel Trailers  >  Small TT's
 > single axel or double
Silvergray49
N. California
Posted: 01/08/19 07:18pm Link  |  Quote  |  Print  |  Notify Moderator
I am looking at 18ft trailers. I can get a single axel or a double axel, Micro Minnie by Winnebago. I like the idea of a double axel, but my friend said they are harder to back up. I love the suggestions I get here so what is your opinion. Thanks in advance.
K Charles
Connecticut
Posted: 01/08/19 07:29pm Link  |  Quote  |  Print  |  Notify Moderator
While backing up, If you make the TT go where you want it to go, your tow vehicle will follow regardless of how many axles the TT has.
ScottG
Bothell Wa.
Nothing hard about backing up a double.
I would not make the number of axles a determining factor with a trailer that size.
Scott, Grace and Wesly
2018 Silver Fox 32A.
H0NDA eu2000i
donn0128
Pronounced Ore-gun
Posted: 01/08/19 07:30pm Link  |  Quote  |  Print  |  Notify Moderator
IMHO single axle trailers are harder to handle. Dual axle trailers will double the suspension maintenance required, but when a flat happens at least you will have another tire to carry the load until you can get stopped.
Don,Lorri,and Charlie Bear 2016
8 years OSP Camp Host
The Other Dallas
Ivylog
Blairsville, GA and WPB, FL.
Posted: 01/08/19 07:37pm Link  |  Quote  |  Print  |  Notify Moderator
Double...more stable.
08 HR Navigator 45'
Sold 04 Dynasty after 14 great years.
How I tow.
Towing a Prius without a dolly
How I spend the winter.
old guy
Oregon (pronounced Or e gun)
Posted: 01/08/19 07:54pm Link  |  Quote  |  Print  |  Notify Moderator
I wonder where he got the idea about being hard to back up a double. go double hands down. if you have ever had a flat with a double you would know what we mean by going double. a flat or blowout with a single you would have more damage to the under carriage then the TT is worth. true doubles blow out can cause damage but the benefits are so much greater don't count having to buy four tires instead of two every 5 to 7 years. think safety and benefits on having a double
1320Fastback
Vista, Ca
Posted: 01/08/19 07:57pm Link  |  Quote  |  Print  |  Notify Moderator
Dual axle is more stable and has better road and highway manners.
Yes the tires scrub when turning tight but is nothing your truck can't handle.
1992 D250 Cummins, 5spd, 4"' straight piped, sensors deleted, airbags, DAP injectors, 18cm.
Silvergray49
N. California
Posted: 01/08/19 08:04pm Link  |  Quote  |  Print  |  Notify Moderator
Thank all of you for confirming what I was thinking. Duel is the only way to go. Now to get some reviews on the Micro Minnie by Winnebago and I am ready to hit the road again.
valhalla360
No paticular place.
Posted: 01/09/19 01:16am Link  |  Quote  |  Print  |  Notify Moderator
Your buddy has it backwards. Dual axles back easier...though the difference isn't enough to worry about.
I would let the number of axles be a factor. Get the trailer that has a better layout for your use. Only reason I might consider it is if you think the cargo carrying capacity is too low with the single axle.
Tammy & Mike
Ford F250 V10
2008 Copper Canyon 5er
Catalac Catamaran 34'
Full Time spliting time between boat and 5er
Lynnmor
Red Lion
Posted: 01/09/19 01:57am Link  |  Quote  |  Print  |  Notify Moderator
Be sure that the trailer has at least 14" wheels. Some of the Micros had two axles with 13" wheels and only cheap Chinese tires are available for those.
