RV.Net Open Roads Forum: Tow Vehicles: DEF for my Dodge?
Search only in Tow Vehicles
 > DEF for my Dodge?
Elwoodj
Decatur, Ga
Posted: 01/09/19 08:30am Link  |  Quote  |  Print  |  Notify Moderator
Does anyone get their def from flying j or Pilot for their Dodge truck (I have a 3500 Ram 2018)?
js9234
Posted: 01/09/19 08:45am Link  |  Quote  |  Print  |  Notify Moderator
Yes, all the time. No issues at all.
Humpty
Clayton, NC
Posted: 01/09/19 08:52am Link  |  Quote  |  Print  |  Notify Moderator
I have not, but only because I can't fuel in the truck lanes. Unfortunately, the truck fuel nozzles do not fit my Canyon. If I could, I would when convenient.
I usually need a DEF fill with each oil change, so I include that with oil change supplies. I usually keep a 2.5 gal jug in the garage with my other consumable supplies (just in case).
* This post was edited 01/09/19 09:08am by Humpty *
2007 Challenger 33DBB parked on the Coast
2016 GMC Canyon Diesel
Second Chance
Wherever...
X2^^. What truck you have doesn't make any difference, though. Major truck stops are good sources of DEF. This is because they pump such volumes of the stuff for the big rigs it's always fresh. You have to be careful about checking the dates on the DEF you buy in jugs at Walmart and parts stores.
Rob
U.S. Army retired
2016 Grand Design Reflection 337RLS
MOR/ryde independent suspension, disc brakes, LR G tires
PullRite OE 18K, Demco Glide Ride pin box
2012 F350 CC DRW Lariat 6.7
Full-time since 8/2015
ACZL
UPstate,NY
Posted: 01/09/19 08:57am Link  |  Quote  |  Print  |  Notify Moderator
I usually need a DPF fill with each oil change, so I include that with oil change supplies. I usually keep a 2.5 gal jug in the garage with my other consumable supplies (just in case).
While the fuel nozzles may not fit your truck, the DEF nozzle will. It's about the same size as a unleaded gas nozzle. I get my DEF at major chain truck stops and no problem with it.
2017 F350 DRW XLT, CC, 4x4, 6.7
2018 Big Country 3560 SS
"The best part of RVing and Snowmobiling is spending time with family and friends"
"Catin' in the Winter"
ShinerBock
SATX
Posted: 01/09/19 09:01am Link  |  Quote  |  Print  |  Notify Moderator
The truck stops sell it for a lot less too.
IdaD
Idaho
Posted: 01/09/19 09:03am Link  |  Quote  |  Print  |  Notify Moderator
I like to get it at the pump because it fills the tank all the way up. Sometimes I'll use a jug of the cheap stuff from Walmart in a pinch, though. It's all API certified so it's the same stuff.
2015 Cummins Ram 4wd CC/SB
Humpty
Clayton, NC
Posted: 01/09/19 09:07am Link  |  Quote  |  Print  |  Notify Moderator
Yes, I am sure they will fit and I could hit up a truck stop between home and work if needed (with a slight change in route). I have considered it, just not done it.
I used the truck lanes often for fueling my 2009 3500 before going seasonal. Had that truck required DEF, I definitely would have used those bulk supplies.
I guess the point of my rambling is that you should use what ever works for you. The bulk supplies at truck stops are certainly fresher (and probably cheaper). If you are new to needing DEF, you should see a pattern of need pretty quickly.
For me any my little Canyon, it is not very often and not a problem at all. I think I use more washer fluid than DEF [emoticon]
Cummins12V98
on the road
Posted: 01/09/19 09:35am Link  |  Quote  |  Print  |  Notify Moderator
Traveling I mainly use the truck Stops and do fill my "RAM" with dEF at them. Otherwise I pick up PEAK DEF at The WallaCost.
RAM since 2013, Dodge died at the end of the 2012 model year.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
naturist
Lynchburg, VA
Posted: 01/09/19 09:52am Link  |  Quote  |  Print  |  Notify Moderator
Get DEF wherever it is cheapest or most convenient. The composition is spelled out in Federal regs. There is NO allowance for “secret sauce” or any amount of deviation. It’s made of two of the cheapest compounds known to mankind, so incentive to make it cheaper is lacking, as well as outright illegal.
 > DEF for my Dodge?
