RV.Net Open Roads Forum: Tech Issues: Trojan T-1275 Trouble
 > Trojan T-1275 Trouble
theoldwizard1
SE MI
Posted: 01/11/19 03:32pm Link  |  Quote  |  Print  |  Notify Moderator
BFL13 wrote:
Yes it is sort of complicated till you do it in real life. Switch A makes it a typical three stage converter and if you monkey with the pot with the switch set to the left, it will change all three voltages at once. You can restore that to original though.
The real benefit is as a singe voltage manual charger with switch A to the right, set to any voltage you like with the pot B.
Maybe not a perfect solution, but much better than most other "smart" chargers which have no manual mode !
And the price is reasonable.
theoldwizard1
SE MI
Posted: 01/11/19 03:44pm Link  |  Quote  |  Print  |  Notify Moderator
MakerMK wrote:
The controller is a Xantrex C35 PWM type. It can be set up for different charging profiles so it is pretty ideal for atypical batteries. But of course it doesn't work if the power supply has a bad connection.
This is GREAT news ! Thank you for reporting back !
I skimmed that owners manual and the setup for that charge controller is not trivial, it is not that difficult either.
theoldwizard1
SE MI
Posted: 01/11/19 04:06pm Link  |  Quote  |  Print  |  Notify Moderator
MakerMK wrote:
Another thought is to use a simple power supply to drive the Schneider charge controller and don't even use the camper's built in charger. I'm sure that your suggestion to get another charger would work, but wouldn't it be more cost effective to make use of what I already have?
I think that is what I would do !
You do not need a 30V power supply. If you are NOT going to equalize (i.e. leave the charge controller on manual equalize mode) than a power supply capable of providing at least 1V MORE than the Bulk Charging Voltage should be sufficient.
In other posts Megawatt Power Supplies have gotten good reviews. While their supplies only claim a maximum output of 15.5V if you called and asked I'll bet they can set you up with one that would do 16V.
2112
Posted: 01/12/19 06:40pm Link  |  Quote  |  Print  |  Notify Moderator
You can boost the Megawatt output to over 16V with THIS. There are lesser boost modules if the 30A model is overkill.
2013 KZ Durango 2857
