RV.Net Open Roads Forum: Fifth-Wheels: Store Hot Water
 > Store Hot Water
powellmj
Benton, AR
Posted: 01/09/19 12:16pm Link  |  Quote  |  Print  |  Notify Moderator
I searched the forums and really couldn't find anything to help with my questions (So much great stuff on here) We recently found ourselves living in our 5th Wheel for an extended amount of time. Home, construction, land, legal.....Anyway, I was wondering if some of you have ever added any type of additional HW storage? Seems like you cold place an insulated tank inline with the HW and increase capacity? With us and 2 kids, the 6-gallon tank does not last long. I don't really have the money or expertise to replace existing HW system with one of the new tankless system. Yes, we do turn it on and off and try to take quick showers and I bought the Oxygenics showerhead, which does help. Since we will be stationary for several months, I'm also not worried about the added weight. So, outside of tankless options, how have any of you increased your HW capacities? Thanks!
jkwilson
Indiana
Posted: 01/09/19 12:47pm Link  |  Quote  |  Print  |  Notify Moderator
The easiest way to increase hot water on some rigs is to turn on both the LP and electric modes. Faster reheating makes it go further.
John & Kathy
2014 Grand Design Reflection 303RLS
2014 F250 SBCC 6.2L 3.73
agesilaus
North Florida
Posted: 01/09/19 12:55pm Link  |  Quote  |  Print  |  Notify Moderator
Maybe something like this: Expansion tank. Ideal would be a residential hot water heater but they are big, very heavy and expensive. I'm not sure that a well expansion tank would work since the diaphragm may not stand up to hot water.
Have you thought where you will put this in your RV? Anything over ten gallons will be very heavy and you might have to reinforce the floor.
Arctic Fox 25Y Travel Trailer
Straightline dual cam hitch
Superbumper
colliehauler
Mc Pherson KS USA
Posted: 01/09/19 01:11pm Link  |  Quote  |  Print  |  Notify Moderator
I agree with an above poster who said run both propane and electric. Very fast recovery time. It sounds like you are already taking navy type showers. You could possibly modify the plumbing to use a house type water heater leaving it outside the trailer.
wildtoad
Blythewood, SC
Posted: 01/09/19 01:23pm Link  |  Quote  |  Print  |  Notify Moderator
The only way I see adding another tank inline is if that tank was another water heater or a solar water tank sitting in the direct sun plumbed into the cold water side of your current wh.
Tom Wilds
Blythewood, SC
BB_TX
McKinney, Texas
Posted: 01/09/19 01:26pm Link  |  Quote  |  Print  |  Notify Moderator
Even an insulated tank would cool down fairly quickly when water was not flowing. You would need to build some type recirculating system to keep the reserve tank hot.
Super_Dave
Harrisville, UT
Posted: 01/09/19 01:45pm Link  |  Quote  |  Print  |  Notify Moderator
When I turn my water heater off, the water is still scalding hot hours later. A dual wall, insulated tank would get a family through dinner dishes and a few showers. OP, does you family practice military showers to conserve hot water?
Truck: 2006 Dodge 3500 Dually
Rig: 2018 Big Country 3155 RLK
Boat: 2003 Jetcraft 2125 - Yamaha 150 HP & 8 HP Kicker
midnightsadie
ohio
not real hard to sit a 40gal outside the unit and plum in. call a mobil tech and talk to them price should be affordable.
greende
Syracuse,NY
Posted: 01/09/19 02:25pm Link  |  Quote  |  Print  |  Notify Moderator
Put in a point of use tank. They come in anything from 2 to 10 gallon and sold at HD & Lowes. Small enough to fit under a sink. Most can be used as a booster so can be plumbed into the hot water line out of the existing water heater. Don't know if you have a 50 amp 5er or not. If you do, it is easy to do. If only 30 amp service, you may want to run a separate 20 amp line to the pedestal.
2011 Chevy 3500 HD LTZ Duramax/Allison Crew Cab Long Box DRW
B&W Turnover Ball with Companion
2012 Keystone Cougar 293 SAB 5er
USAF 1968 - 1972 Viet Nam '71 - '72
tchil
Woodland Park, CO
Posted: 01/09/19 02:26pm Link  |  Quote  |  Print  |  Notify Moderator
When we lived in our toyhauler in Colorado during the winter I discovered that the temperature of water coming into the water heater had a huge effect on how long the hot water would last for showers.
I installed an on demand propane water heater inline on the input side of the water heater. This used 2 D batteries for ignition and connected to a regular ground mounted bbq style propane tank. It would take our 40 degree water and raise the temp into the 70's. This allowed us to take pretty normal showers.
You could also look for a small electric unit like they use under the counter or cabinets in many commercial applications and put it in the basement or even under the trailer you would just have to figure out how to get electricity to it.
* This post was edited 01/09/19 03:31pm by tchil *
Ty
2018 Ram Cummins Mega
2007 Ragen Blackhawk 36-05
 > Store Hot Water
