RV.Net Open Roads Forum: Tech Issues: convert gas generator to propane
 > convert gas generator to propane
johntank
North MS
Posted: 01/09/19 12:23pm Link  |  Quote  |  Print  |  Notify Moderator
Has anyone done this conversion on a Onan 4K and what was the cost and where did you find the best price on parts needed.
Thanks John
wildtoad
Blythewood, SC
Posted: 01/09/19 01:11pm Link  |  Quote  |  Print  |  Notify Moderator
If this is in a motor home why would you do that unless it’s permanently parked somewhere.
Tom Wilds
Blythewood, SC
fj12ryder
Platte City, MO
Posted: 01/09/19 01:19pm Link  |  Quote  |  Print  |  Notify Moderator
I've thought about doing it with my 5500 Onan, just to make sure that it doesn't get gummed up with gas when it sits for long periods. I've not done it, but it looks relatively easy to do and there are kits on Ebay, and other places that make it look pretty easy.
OTOH, if you use the generator much propane usage is pretty high.
Howard and Peggy
"Don't Panic"
sjholt
Henderson, NV
Posted: 01/09/19 01:29pm Link  |  Quote  |  Print  |  Notify Moderator
deleted
Skip
1996 32' Monaco Windsor DP
Cummins 5.9L 230+ HP
5 Airbags in front- 4 in back
johntank
North MS
Posted: 01/09/19 01:44pm Link  |  Quote  |  Print  |  Notify Moderator
wildtoad, no it is in a 5er,
fj12ryder, yep getting tired of a gummed up carb after sitting longer than two months and yes I do know propane use will be higher and cost a little more.
fj12ryder
Platte City, MO
Posted: 01/09/19 02:30pm Link  |  Quote  |  Print  |  Notify Moderator
I've had mine for 8 years and use the generator very, very infrequently, and have had no issues with the carb gumming up. I thought it would be an issue since we are fully connected almost all the time. But it hasn't been a problem. I drain the carb bowl after I'm through using it, and it always starts right up when I start it again months, sometimes many months, later. It usually gets started maybe once or twice a year. I never use any stabilizer, never drain the gas tank, and the same gas has been in there for a good 5 years. Like I said, so far no problems.
Now watch, it won't run for sour apples this year. LOL
Dusty R
Charlotte Michigan 48813
Posted: 01/09/19 03:21pm Link  |  Quote  |  Print  |  Notify Moderator
On our '01 Itasca 24' mh I installed a switch on the fuel pump, and when I knew that we were not going to use the generator for a while I would turn the fuel pump off and let the generator run out of gas. That worked fine. Never had a problem with gummed up carb.
Dusty
JaxDad
Greater Toronto Area
Posted: 01/09/19 04:20pm Link  |  Quote  |  Print  |  Notify Moderator
If the Onan is in a 5’er it must then have its own fuel tank. It would be pretty easy to dose it up with SeaFoam then compared to a m/h where the fuel supply is the chassis tank.
Seems a bunch easier to just prevent the gumming up in the first place.
johntank
North MS
Posted: 01/09/19 05:54pm Link  |  Quote  |  Print  |  Notify Moderator
Since I have not gotten any info on the conversion I will not be checking in for some time, maybe several days.
Thanks
MrWizard
Traveling
Posted: 01/09/19 06:22pm Link  |  Quote  |  Print  |  Notify Moderator
no info, because converting a built in gasoline onan
is a Very Rare thing
people usually convert portable generators
or maybe a stick house emg backup generator
BTW we had a Dp with LP onan, it was a liquid feed system
with a vapor/converter at the genny, needs a special LP tank
diy conversion kits for gas to LP use vapor systems and standard bottles,
Radiate The Happy
1997 F53 Bounder 36s
