RV.Net Open Roads Forum: Class A Motorhomes: Opinions Please
 > Opinions Please
Executive
Posted: 01/09/19 08:42pm Link  |  Quote  |  Print  |  Notify Moderator
For the technically challenged: [emoticon]
Clicky
The VIN shows it's a 2006 stripped chassis, so that's when the chassis was built. My guess is the coach was put on the following year, hence the 07 model. VIN check does show a recall on that unit, so you might want to ask about that....BTW, I like the interior colors. [emoticon]....Dennis
A Simple Act of Caring Creates an Endless Ripple
Dennis and Debi Ten Years Full Timing
2014 Chevrolet Equinox LTZ W/ ReadyBrute
CLICK HERE TO VIEW OUR TRAVEL BLOG
6ofus
bartlett,il 60103
Posted: 01/10/19 05:45am Link  |  Quote  |  Print  |  Notify Moderator
Clicky
Thanks for the "clicky". I should have done that to begin with.
It was mentioned earlier that the tow capacity is low. Researched a little more and I see that the tow capacity is 4500.
jarata1
Massachusetts
Posted: 01/10/19 08:33am Link  |  Quote  |  Print  |  Notify Moderator
looks nice you will know in your heart if its th right one dont buy something and wonder just love your new purchase
scbwr
North Ridgeville, OH
Posted: 01/11/19 07:10pm Link  |  Quote  |  Print  |  Notify Moderator
If that unit had been advertised last spring when we were looking, I would have probably gone to look at it! If it is mechanically in really good shape, you may have to consider a few things. The carpeting may not look as good as it does in the pics....had that happen with a 2008 HR gasser that we went to look at. And, in those years, that can be a lot of carpet to replace which can be pretty pricey if you can't do it yourself. You may find that it's time for a sofa upgrades, but that isn't a problem as long as you plan for it financially. I'd be surprised if it doesn't need a set of tires and possibly a brake job. If so, you can save some bucks by going with Toyo or other tires that aren't as expensive as Goodyears or Michelins. Also, you may want to replace the mattress. But if the price is right and you have some money in the budget for upgrades, it could be a good way to hit the road.
One more point....make sure it has two AC units. In a motorhome that size, you really need two AC units if you are going to be in hot summer weather. Also, find out the size of the generator. I suggest making sure that it has enough capacity to run both AC units at the same time or at least a power management system to effectively alternate between the two. Another cost may be replacing the coach battery and/or the house batteries. I don't mean to sound negative, but when looking at a used motorhome, there's a lot of stuff that does wear out and you don't want to purchase one without being prepared for some expenses.
If you don't want to worry about expensive repairs, you could look at getting an extended warranty, but they are pricey and many would argue that you're better off to take the cost of one and just put that money aside and save it as a repair fund.
Good luck in your search.
2012 Newmar Bay Star 3302
Blue Ox Avail
BrakeBuddy Advantage
2015 Malibu
"Get busy living, or get busy dying."
Andy Dufresne, The Shawshank Redemption
 > Opinions Please
