RV.Net Open Roads Forum: Fifth-Wheels: Cre3000 to CRE4000
 > Cre3000 to CRE4000
sayoung
Tx
Posted: 01/09/19 02:49pm Link  |  Quote  |  Print  |  Notify Moderator
Anyone replace the Moryde CRE3000 equalizer with the 4000 ? If so, worth the cost or just go the Joyriders shock kit ?
2naEagle
McCalla, AL
Posted: 01/09/19 04:24pm Link  |  Quote  |  Print  |  Notify Moderator
I did both and very satisfied.
Heavy duty shackles and wet bolts also
2017 North Point 315RLTS
Disc Brakes/Joy Rider Shocks/SRE4000/EMS-HW50c/Hughes Autoformer/TST507
2017 F350 CCSB SRW
50 gal aux tank/Rancho 9000xl/air bags/Hellwig Big Wig Sway Bar/Trailer Saver BD5
sayoung
Tx
Posted: 01/09/19 07:24pm Link  |  Quote  |  Print  |  Notify Moderator
I didn't realize how much difference between my 3000's that came on our 5er and the 4000. Our rig also came with the shock mounts but with the axles flipped no body has been able to get me a shock that fits. Not Jayco or LCI, Monroe won't give me a clue either.
Did you do both 4000 & Joyrider at same time ?
2naEagle
McCalla, AL
Posted: 01/09/19 09:22pm Link  |  Quote  |  Print  |  Notify Moderator
I did the joyrider's first. I could tell that things stayed in place a little better in the trailer (like the microwave plate). I put the 4000's on because I wanted to and had to much time on my hands at the time.[emoticon]
I am very happy with them. It mostly just depends on how many miles you pull. Anything you do has to be better than stock.
All of these upgrades and a air ride hitch makes for a very pleasant ride.
2naEagle
McCalla, AL
Posted: 01/09/19 09:35pm Link  |  Quote  |  Print  |  Notify Moderator
Post some pictures and some measurements maybe someone on here can help.
I had a 2008 Eagle 291rlts it had mounts and no shocks. I put dexter shocks on it. But it was stock.
RollandB
Albany, Or
Posted: 01/10/19 08:35am Link  |  Quote  |  Print  |  Notify Moderator
I did the change last summer. Already had shocks on ours, since they were OEM shocks changed them to Monroe Gas Magnums.
I continue to see a significant improvement in the ride especially going over bridge joints. I credit this mostly to the SRE4000. Only downside is the 5er is about 3/4” taller at the high point.
2005 Silverado 3500 Crew Cab Long Box, Duramax/Allison, B&W Companion, TST507's
2016 Artic Fox 27-5L
sayoung
Tx
Posted: 01/10/19 09:04am Link  |  Quote  |  Print  |  Notify Moderator
I have exactly 11 inchs between the mounting holes. The LCI black ones are too short & the yellow ones too long. Jayco & LCI both says the yellow ( which I purchased ) is the shock but that would require putting the spring in the 1st Hole From the ground & I don't need any more top clearance as it's 13ft 2 in now
I think for noe upgrade to the 4000 & see how it rides
ACZL
UPstate,NY
Posted: 01/10/19 09:10am Link  |  Quote  |  Print  |  Notify Moderator
Our Big Country came w/ the 3000's and was considering bumping up to the 4000's. Current ride, have no problem w/ coach, just wanted to go to the 4000's. However, on the HL forum, a owner had the 4000's and the rubber gave way inside the alum housing (in other words the rubber got pushed downwards thru the alum). After seeing that, gave me 2nd thoughts about switching. Just a thought/sayin'.
2017 F350 DRW XLT, CC, 4x4, 6.7
2018 Big Country 3560 SS
"The best part of RVing and Snowmobiling is spending time with family and friends"
"Catin' in the Winter"
buc1980
houston tx
Posted: 01/10/19 12:14pm Link  |  Quote  |  Print  |  Notify Moderator
Hold on your money and save to install the Mor/ryde IS.If you really need(want) a smooth ride.
2017 Ford F350 DRW,2005 Kountry Star 35ft,14750 lb weight on SAILUN tire,6 points LIPPERD Level-up.New Mor/ryde IS suspension install.
GHop
California
Posted: 01/10/19 04:33pm Link  |  Quote  |  Print  |  Notify Moderator
I will be installing the 4000 as an upgrade just need to find the time.
