RV.Net Open Roads Forum: Fifth-Wheels: Cre3000 to CRE4000
 > Cre3000 to CRE4000
sayoung
Tx
Posted: 01/10/19 05:09pm Link  |  Quote  |  Print  |  Notify Moderator
GHop wrote:
I will be installing the 4000 as an upgrade just need to find the time.
If we were full time probably would but for 5 or 6 trips a year and usually only couple hours drive not really smart money. Heck, on the fence about upgrading the equalizer due to $ .
sayoung
Tx
Posted: 01/11/19 02:23pm Link  |  Quote  |  Print  |  Notify Moderator
I talked to LCI again today about the shock mounts being welded from the factory. I had a different person today, Katie , and she is sending me the mounts from the addon kit that the others have been telling me can't get. I have to say LCI sometimes does do right.
When they arrive will remove the welded ones, may just mount on the inboard side while doing the wet bolts. If not a great improvement will reconsider the 4000
lenr
Indianapolis, IN
Posted: 01/11/19 06:13pm Link  |  Quote  |  Print  |  Notify Moderator
We went from the Lippert equivalent of the 3000 to the 4000. Night and day difference! The Lippert cushioned equalizer never seemed to make a difference. With the 4000 we only feel the trailer hit bumps 2% of the time--like never. Note: we had a MORryde pin box with both systems. Part of the time with the 4000 the microwave plate is still in place after a drive while it never was before the 4000. Our next new trailer will get a 4000 or IS immediately.
jaycocamprs
Ringgold Georgia
Posted: 01/12/19 03:05pm Link  |  Quote  |  Print  |  Notify Moderator
sayoung wrote:
I didn't realize how much difference between my 3000's that came on our 5er and the 4000. Our rig also came with the shock mounts but with the axles flipped no body has been able to get me a shock that fits. Not Jayco or LCI, Monroe won't give me a clue either.
Did you do both 4000 & Joyrider at same time ?
Monroe 555001 Compressed Length 7.875" Extended Length 11.875" Travel Length 4.000"
Monroe 555026 Compressed Length 8.625" Extended Length 13.500" Travel Length 4.875"
Both are Stem Mount, with rubber bushings.
2018 Silverado 3500 DRW
2011 Montana Mountaineer 285RLD
2naEagle
McCalla, AL
Posted: 01/13/19 06:17am Link  |  Quote  |  Print  |  Notify Moderator
I knew someone out there would step up.
2017 North Point 315RLTS
Disc Brakes/Joy Rider Shocks/SRE4000/EMS-HW50c/Hughes Autoformer/TST507
2017 F350 CCSB SRW
50 gal aux tank/Rancho 9000xl/air bags/Hellwig Big Wig Sway Bar/Trailer Saver BD5
sayoung
Tx
Posted: 01/13/19 09:34am Link  |  Quote  |  Print  |  Notify Moderator
Thanks but I had that info way back. Without moving to Hole for highest ground clearance which I don't need any more height , 13'2" now. I have the longer 026 and with the rubber mounts you can't install without removing spring from shackles then you have very little compression travel & will bottom out which is worse than no shock absorber. The shorter just the opposite. Like I said LCI sending me new mounts FREE.
jaycocamprs
Ringgold Georgia
Posted: 01/13/19 12:33pm Link  |  Quote  |  Print  |  Notify Moderator
I did the 026s on a old Eagle we had, but it had been raised all the way up. I never did it again because after less than 2 years they were worn out.
I do like the look of the Joyrider's kit. Lowers the the lower mount for lot more travel. A lot more choices in that style of mount also. But for those $$ I would do Trailair pinbox
ChuckV1
Rochester WA
Posted: 01/20/19 01:57pm Link  |  Quote  |  Print  |  Notify Moderator
We also went from the Lippert equivalent of the 3000 to the MorRyde SRE4000. Night and day difference! The Lippert cushioned equalizer never seemed to make a difference. Like the OP with the 4000 we only feel the trailer hit bumps 2% of the time. We have had a MORryde 18k pin box with both suspensions, but when upgrading to the SRE4000 we also added the three X-factor cross members, one across each spring hanger front an rear an across the center ...
I will also say most of the time with the SRE4000 the microwave plate is still in place after a drive while it never was before the LCI suspension as well our coffee pot, toaster never moves now on the counter top [emoticon]
ACZL
UPstate,NY
Posted: 01/21/19 10:42am Link  |  Quote  |  Print  |  Notify Moderator
deleted
2017 F350 DRW XLT, CC, 4x4, 6.7
2018 Big Country 3560 SS
"The best part of RVing and Snowmobiling is spending time with family and friends"
"Catin' in the Winter"
GHop
California
Posted: 01/24/19 05:12pm Link  |  Quote  |  Print  |  Notify Moderator
I think I ordered the wrong one. Where did you guys take your measurements from? I went by an Rv web site which said to measure from center wheel hub to center wheel hub which measured on my rig 35inches so I purchased the SRE2 735x. After going on MorRyde I found they wanted you to measure from one hanger to the second hanger so for my rig it was 59inches.
* This post was edited 01/25/19 10:08am by GHop *
