RV.Net Open Roads Forum: Tech Issues: Simple Inverter Option
 > Simple Inverter Option
Grodyman
Posted: 01/09/19 02:56pm Link  |  Quote  |  Print  |  Notify Moderator
I want to run television/dvd player off inverter and charge electronics.
There is no 12V outlet in rv and the geniuses at Passport put the outlets, including the one the television plugs into, on the same breaker as the converter, so the simple plug shore cord into inverter won't help.
Any suggestions? Battery inside rv with dedicated outlet? Drill a bunch of holes in my trailer to run an extension chord? Read a book??
Gman
2017 F150 CC/5.5' 4x4 3.5 Ecoboost/3.55
2018 Passport Ultra-Lite 153ML
2oldman
New Mexico
Posted: 01/09/19 02:58pm Link  |  Quote  |  Print  |  Notify Moderator
Many of us put an spst switch in the converter's 120v side to turn it off. If you don't know what spst is, better read a book.
naturist
Lynchburg, VA
Posted: 01/09/19 03:01pm Link  |  Quote  |  Print  |  Notify Moderator
It's what I've done to add a backup camera, and will do to go solar. Ain't nothing sacred anymore, certainly not with regard to adding wires to your camper.
camperdave
northern, California
Posted: 01/09/19 03:13pm Link  |  Quote  |  Print  |  Notify Moderator
I was able to easily rewire the converter to a different breaker inside of the distribution panel.
I am not plugging the shore cord into the inverter, but I did wire in a simple 15a transfer switch that controls only the circuits that outlets are on (once I moved the converter to a different circuit).
2004 Fleetwood Tioga 29v
Ductape
On the Road
Posted: 01/09/19 03:20pm Link  |  Quote  |  Print  |  Notify Moderator
Just install a 12v plug, get a 400w or so plug in inverter and you’re good to go. No need to get complicated just to watch tv.
49 States, 6 Provinces, 2 Territories...
time2roll
Posted: 01/09/19 03:28pm Link  |  Quote  |  Print  |  Notify Moderator
I would move the converter power connection to a different breaker. Actually I added a breaker to isolate it.
Add a small 150 to 350 watt sine inverter near the distribution panel. Connect 12v to the main battery feed. Use a small transfer switch to send power down the single branch.
I used a GoPower inverter as it has a very low idle draw and a provision for a remote power switch.
675w Solar pictures back up
2oldman
New Mexico
Posted: 01/09/19 03:52pm Link  |  Quote  |  Print  |  Notify Moderator
That's usually a pretty long run from the battery, so make sure your 12v wire is big enough. Easier to push 120v than 12v.
BFL13
Victoria, BC
Posted: 01/09/19 03:54pm Link  |  Quote  |  Print  |  Notify Moderator
Some converters are hard wired to the 120v breaker, while others are plugged into a receptacle, which in turn is on a 120v breaker.
So if the one breaker is doing both converter and TV receptacle, that might mean all you have to do is unplug the converter and leave the receptacles' breaker on.
If hard wired, as others said, just move the black wire from the converter over to a different breaker not needed and share with that, or even add a breaker if there is room on the bus.
If hard wired , you can also as said, insert a switch on the black wire from the converter before it gets to the breaker.
1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
See Profile for House electronics set-up.
Wherever I happen to park
Posted: 01/09/19 04:19pm Link  |  Quote  |  Print  |  Notify Moderator
If you can run a dedicated line to ther TV compartment from the inverter and simply transfer. .There are easy ways to do this a photo of the Entainerment area I can make suggestions.
Home is where I park it.
bpounds
Senile, er I mean
Posted: 01/09/19 04:28pm Link  |  Quote  |  Print  |  Notify Moderator
I wanted to do exactly what you want to do. Watch TV and videos off-grid.
I ordered this inverter:
Inverter Link on Amazon
I ordered this USB outlet for charging:
USB 4 Port Outlet
That inverter has provision for a remote on/off switch. No need to interrupt power to the inverter, just turn it off with a remote switch. This inverter is a pure sine wave. I tried a MSW plugged into the 12VDC outlet, which I do have one, but no go for our TV. A PSW is not expensive, so why not treat your electronics to good tasting power.
That USB outlet is a 12VDC, which worked for me because I had a 12VDC source in that wall. If you don't, you can get the same outlet in a 120VAC version.
The inverter is in the storage compartment. Had to run a few wires, but it wasn't any big deal to do that.
Ended up looking like this:
The Ivory outlet is the original and is still on the house power. The TV is currently plugged in to that in this photo. When we move off of shore power, I move the TV plug to the White outlets and hit the White switch to power up the inverter. The USB ports are live all the time, on or off the grid.
2006 F250 Diesel
2011 Keystone Cougar 278RKSWE Fiver
