RV.Net Open Roads Forum: Truck Campers: Would you..
 > Would you..
TxGearhead
Posted: 01/09/19 07:05pm Link  |  Quote  |  Print  |  Notify Moderator
...carry 4 or 5 gallons of gasoline in a Berg long run fuel tank (boat gas tank) in the basement of a TC? In a plastic tub? With an old style closable vent on the tank cap?
I haven't done it yet, but I'm tempted if it is required.
Unfortunately I have a A/C on my Bigfoot that requires 2 Honda 2000 gens to run. Why Bigfoot, why?
I don't mind giving away $10 worth of gas rather than driving home 800 miles with the gas in the basement.
Your opinions welcomed....
Yeah I worked in a refinery for 40 years....
2018 Ram 3500 CC LB DRW 4X4 Cummins Aisin Laramie Pearl White
2014 Montana High Country 305RL
2008 Bigfoot 25C9.4
2014 NauticStar 21 ShallowBay 150HP Yamaha
2016 GoDevil 18X44 35HP Surface Drive
jplante4
Cape Cod
Posted: 01/09/19 07:09pm Link  |  Quote  |  Print  |  Notify Moderator
Can you strap it to a ladder?
Jerry & Jeanne
1996 Safari Sahara 3530 - 'White Tiger'
CAT 3126/Allison 6 speed/Magnum Chassis
2014 Equinox AWD / Blue Ox
TxGearhead
Posted: 01/09/19 07:20pm Link  |  Quote  |  Print  |  Notify Moderator
With gas in it? No.
jimh425
Western MT
Posted: 01/09/19 07:25pm Link  |  Quote  |  Print  |  Notify Moderator
Sounds like a bomb, so no I wouldn’t put several gallons of gasoline under my TC.
Old Days
Colorado
Posted: 01/09/19 07:30pm Link  |  Quote  |  Print  |  Notify Moderator
Just a idea,could you mount a fuel tank between the frame of the truck. Or maybe some kind of a bracket that would hold a small fuel can. I would worry about gas fumes in the basement of my TC.
Buzzcut1
Norcal
Posted: 01/09/19 07:44pm Link  |  Quote  |  Print  |  Notify Moderator
I carry three 2.5 gallon plastic fuel cans in the vented compartment originally designed for an onboad genset. 8 years no issues no fumes to fuel my Honda 2000
2011 F350 6.7L Diesel 4x4 CrewCab longbed Dually, 08 Lance 1055, Torqlift Talons, Fast Guns, upper and lower Stable Loads, Super Hitch, 48" Super Truss, Airlift loadlifter 5000 extreme airbags
Kayteg1
California > Nevada
Posted: 01/09/19 07:50pm Link  |  Quote  |  Print  |  Notify Moderator
Years ago I bought gas cans in Canada. Even they cost like $7 a piece, they are much stronger than what you can buy in US and have gargling nozzle instead of spring loaded valves, where spring flies away on 2nd use.
I do carry 2 of those in empty generator compartment.
For short trip I would not hesitate to put it behind driver seat, but they do smell a bit.
Boat tanks are not any stronger and than they are not design for pouring fuel out.
Than you can always buy military style metal gas cans.
burningman
Seattle, WA USA
Posted: 01/09/19 08:13pm Link  |  Quote  |  Print  |  Notify Moderator
I’ve done it with a trailer-hitch-mounted carrying rack on the back, behind the truck and below the camper. If your Honda’s don’t fit in your generator compartment, put the gas cans there.
2017 Northern Lite 10-2 EX CD SE
99 Ram 4x4 Dually Cummins
A whole lot more fuel, a whole lot more boost.
4.10 gears, Gear Vendors overdrive, exhaust brake
Built auto, triple disc, billet shafts.
Kelderman Air Ride, Helwig sway bar.
BradW
Mayor of Flat Rock
Posted: 01/09/19 09:12pm Link  |  Quote  |  Print  |  Notify Moderator
Change out the ac to one that only requires one Honda and sell the extra ac and extra Honda on Craig's List. Problem solved.
Wake Up America
1996 Lance 500 and 2006 F-350 PSD 4X4 DRW
Our Truck Camper Photos
valhalla360
No paticular place.
Posted: 01/10/19 12:37am Link  |  Quote  |  Print  |  Notify Moderator
What's the temperature range? I've seen them blow up like a balloon when the valve is closed while cool and then it heats up later in the day.
Much better to use an exterior mounting system.
Tammy & Mike
Ford F250 V10
2008 Copper Canyon 5er
Catalac Catamaran 34'
Full Time spliting time between boat and 5er
 > Would you..
