RV.Net Open Roads Forum: Installed a front receiver on my F350 today
 > Installed a front receiver on my F350 today
Buzzcut1
Norcal
Posted: 01/09/19 08:24pm Link  |  Quote  |  Print  |  Notify Moderator
When I did a similar install on my 03 F350 many hears ago there was much cursing, modifying, prying and cracked knuckles. I'm happy to say there there was none of that this go round.
I had a break in the weather this afternoon and decided to tackle the front receiver install.
The receiver is a Curt 31018 specific to the F350 4x4, My 2011 fits the model yr range of this product I got it off Amazon for $115.
I watched the online video and it made the install look easy, It was.
Start to finish took less than an hour. Fishing the bolts through the frame was a piece of cake using the supplied hardware.
The biggest pain in the butt is that without a lift or putting the truck on ramps or jack stands it was really hard to get leverage on my big torque wrench and crank the bolts to 110/ft pounds. my shoulders and arms got a work out.
The only tools I needed were a 3/4 socket, a ratchet wrench, a torque wrench, a small flat head screwdriver (to stick in the bolt threads to prevent them bolts from falling back into the frame while I removed the fish wire and screwed on the nut), and a dremel tool to cut the notch in the plastic air dam.
The vertical fins go on first then the cross bar upside down to mark where you will cut the air dam. flip the cross bar add the bolts, tighten and torque
The kit
In place
air cam cut
Honda 2000 in a Torklift Sidekick rack ready to go
* This post was edited 01/09/19 08:36pm by Buzzcut1 *
2011 F350 6.7L Diesel 4x4 CrewCab longbed Dually, 08 Lance 1055, Torqlift Talons, Fast Guns, upper and lower Stable Loads, Super Hitch, 48" Super Truss, Airlift loadlifter 5000 extreme airbags
work2much
Jackson Ca
Posted: 01/09/19 08:35pm Link  |  Quote  |  Print  |  Notify Moderator
Easier install than on my Ram. You might want a cover for the generator to protect it from water, bugs, etc.
2017 Ram 3500 Laramie CTD DRW Crew 4x4 Aisin 4:10 Air ride.
2018 Host Mammoth. 1080 Watts solar. 600 AH usable LFP battery. Magnum 2800 Watt inverter.
2018 Jeep Wrangler Unlimited toad.
Buzzcut1
Norcal
Posted: 01/09/19 08:37pm Link  |  Quote  |  Print  |  Notify Moderator
I have one but it makes for a crappy demonstration photo [emoticon]
jimh425
Western MT
Posted: 01/09/19 09:32pm Link  |  Quote  |  Print  |  Notify Moderator
Nice job!
1handyhubby
San Diego
Posted: 01/09/19 09:44pm Link  |  Quote  |  Print  |  Notify Moderator
Sweet. Where did you get the cargo carrier and how much was it? Just installed a front receiver on my 2001 F350 and am using the fold up carrier which is larger than I like. Thanks
2001 F350 Lariat V10 DRW 4x4,4.30 rear, Rancho 9000's,
Ride Rite air bags w/onboard compressor, Tork Lifts, Fastguns,
2013 Host Mammoth Happy Happy Wife!
Buzzcut1
Norcal
Posted: 01/09/19 10:11pm Link  |  Quote  |  Print  |  Notify Moderator
its a torklift sidekick it is designed for Honda and Yamaha 2000-2200 generators. keeps them secure while driving and from 5 finger discount shopping in camp. all the online hitch places carry them. theyalos have a version for the 3000 watt gensets.
Kayteg1
California > Nevada
Posted: 01/09/19 10:58pm Link  |  Quote  |  Print  |  Notify Moderator
Torklift makes nice hardware, but costly.
I posted picture of my front mounted Honda 3000, when couple of members ask me about mount details.
Here is a sketch how I build it with material "laying around"
I only bought additional metric bolts and rubber pads, so my generator sits on rubber mounts both ways.
Metric bolts are hidden from the outside for security.
[image]Click For Full-Size Image.
Comparing the hitches, on my 2017 model the hitch goes lower as it is mounted at the bottom of cross bar.
* This post was edited 01/09/19 11:04pm by Kayteg1 *
TxGearhead
Posted: 01/10/19 06:16am Link  |  Quote  |  Print  |  Notify Moderator
I finally put the front hitch on mine. I took it off the previous RAM. Pretty snug fit trying to torque some of the nuts.
Tell us about those truck front wheel hub caps/lug nuts/studs/whatevers.
I've thought about removing my plastic chrome hub caps and going with chrome acorn nuts.
2018 Ram 3500 CC LB DRW 4X4 Cummins Aisin Laramie Pearl White
2014 Montana High Country 305RL
2008 Bigfoot 25C9.4
2014 NauticStar 21 ShallowBay 150HP Yamaha
2016 GoDevil 18X44 35HP Surface Drive
Buzzcut1
Norcal
Posted: 01/10/19 07:00am Link  |  Quote  |  Print  |  Notify Moderator
Spiked lug nuts. Bought the truck used, it came that way, wife likes em, they stayed.
stevenal
Newport, OR, USA
Posted: 01/10/19 08:40am Link  |  Quote  |  Print  |  Notify Moderator
I think I saw those on Ben Hur.
Thanks for the write up, I may be doing something similar. I'd probably include some sort of stick to provide a visual indication of the new length.
'18 Bigfoot 1500
Torklifts and Fastguns
'17 F350 Powerstroke Supercab SRW LB 4X4
