RV.Net Open Roads Forum: 40' Diesel Pusher wandering on the road
 > 40' Diesel Pusher wandering on the road
klr650goldwing
minnesota
Posted: 01/09/19 10:31pm Link  |  Quote  |  Print  |  Notify Moderator
Yesterday I talked to a guy who said he bought the above referenced rig new and sold it three months later because of how difficult it was to hold on the road. He said the wind blew it around severely. I'd never heard of that before. Is that true?
2011 Crossroads Cruiser, CF325CKP
2004 F350, V10, CC, LB, 4X4, 456
2004 Honda Goldwing GL1800
2004 Kawasaki KLR650
1966 Honda 305 Dream
rk911
Wheaton IL
Posted: 01/09/19 10:53pm Link  |  Quote  |  Print  |  Notify Moderator
did he indicate whether he had it looked at...tires, air bags, etc?
'73,
rich, n9dko
Every retired man needs three things....a good truck, a good dog and a working wife
2016 Itasca Suncruiser 38Q
'46 Willys CJ2A
'03 Jeep Wrangler TJ
'10 Jeep Liberty KK
ArchHoagland
Clovis, CA, USA
Posted: 01/10/19 01:10am Link  |  Quote  |  Print  |  Notify Moderator
If his tires were over inflated and he had an alignment problem and was traveling 70 mph in high winds then I'm sure it would be a nightmare.
However if all those items were corrected and he dropped his speed and stayed out of the storms then I think it would be a different story.
2004 Monaco La Palma 36DBD
Workhorse W22 8.1 Gas Allison 1000, 7.1 mpg
US Gear Brakes
YC 1
Yuba City Calif./ Auburndale Florida
Posted: 01/10/19 03:19am Link  |  Quote  |  Print  |  Notify Moderator
My 2008 HR Endeavor was a white knuckle monster that was NOT fun to drive like my previous RV's. It took a lot of money and patience to calm the beast. It drives nicely now but was dangerous when new. I mean literally dangerous.
H/R Endeavor 2008
2013 Ford Edge toad
Full Timers
js218
norwood pa.
Posted: 01/10/19 04:45am Link  |  Quote  |  Print  |  Notify Moderator
45'Haulmark super C, handles like a dream not affected by wind or passing semi's, if you haven't driven one you would be amazed at how stable they are.
Jim
2017 Haulmark 45' Super C 600hp, 10 speed I shift transmission, tandem drive axles, 3 stage engine brake, towing 26' trailer with an 08 explorer inside.
Jim
w4phj
Vero Beach
Posted: 01/10/19 04:56am Link  |  Quote  |  Print  |  Notify Moderator
Check tire footprint.
Check for plenty of positive caster.
Check for worm and sector play in steering box and
or steering linkage.
2005 Bounder 37U Cat C7 Engine
2014 Jeep Grand Cherokee Limited
2015 Jeep Wrangler Unlimited Sahara
Ham Radio Extra Class Volunteer Examiner
FAA A&P License
1969 Plymouth Road Runner
rgatijnet1
Posted: 01/10/19 05:13am Link  |  Quote  |  Print  |  Notify Moderator
Weigh all four corners when loaded for travel. Most rigs handle better and track better if the front end is loaded close to the maximum axle weight. A light front end will tend to wander and be difficult to manage. This also will give you a chance to adjust your tire pressure to the manufacturer's recommendation.
Bruce Brown
Northern NY
Posted: 01/10/19 05:18am Link  |  Quote  |  Print  |  Notify Moderator
Certainly not normal, but more info would be helpful. "40' diesel pusher" is a pretty wide brush to paint with.
There are 24 hours in every day - it all depends on how you choose to use them.
Bruce & Jill Brown
2008 Kountry Star Pusher 3910
Scottiemom
South Dakota/Indiana
Posted: 01/10/19 05:53am Link  |  Quote  |  Print  |  Notify Moderator
When our Phaeton was new, we had a tire that was wearing strangely and it caused some vibration. At one point, we had to have it replaced and found that the wheel itself was bent. . . we believe it was like that when we bought it new. In order to compensate it had about 26 ounces of weight on it. We replaced both the wheel and the two front tires. Smooth sailing since then.
Dale
Dale Pace
Wife to Terry (Teacher's Pet)
Mom to Scottish Terrier, Duchess
2006 Tiffin Phaeton 40'(Phaeton Place)
2014 Ford Flex
2004 R-Vision Trail-lite 213 (MinnieMee)
Fulltiming since 2005
http://www.skoolzoutforever.blogspot.com/
Where are we?
Ivylog
Blairsville, GA and WPB, FL.
Posted: 01/10/19 06:29am Link  |  Quote  |  Print  |  Notify Moderator
OP, did he tell you what color it was? Sounds like cabin fever is setting in awful early.
08 HR Navigator 45'
Sold 04 Dynasty after 14 great years.
How I tow.
Towing a Prius without a dolly
How I spend the winter.
