RV.Net Open Roads Forum: 40' Diesel Pusher wandering on the road
 > 40' Diesel Pusher wandering on the road
klr650goldwing
minnesota
Posted: 01/10/19 08:31am Link  |  Quote  |  Print  |  Notify Moderator
We just walked briefly along a beach while on a morning walk. So I didn't get to ask him all the questions listed here. It was just a brief encounter that surprised me to the point I wanted to hear from the experts. Thank you
2011 Crossroads Cruiser, CF325CKP
2004 F350, V10, CC, LB, 4X4, 456
2004 Honda Goldwing GL1800
2004 Kawasaki KLR650
1966 Honda 305 Dream
Cloud Dancer
San Antonio and Livingston TX USA
Posted: 01/10/19 09:10am Link  |  Quote  |  Print  |  Notify Moderator
This scenario has be played out over and over. It takes a qualified driver to simply test drive it, and tell you what you need in order to either fix the problem OR get rid of the problem.
One thing is for sure, the caster adjustment is worthless if the front end does not have sufficient weight(load) to produce caster authority.
If you take a empty shopping cart that has a front caster that wobbles like crazy,....just load up the basket and it will solve the problem.
Don't take my word for it, just try a few changes that make sense. But then, this would take someone who knows which chassis features produce good directional stability.
Willie & Betty Sue
Miko & Sparky
2003 41 ft Dutch Star Diesel Pusher/Spartan
Floorplan 4010
Blazer toad & Ranger bassboat
Tom/Barb
Oak Harbor, Wa
Posted: 01/10/19 10:19am Link  |  Quote  |  Print  |  Notify Moderator
In our couch you can feel the wind, but it is no horror story, very easy to compensate. what bothers us more is a rutted road.
2000 Newmar mountain aire 4081 DP, ISC/350 Allison 6 speed, Wrangler JK toad.
Harvard
51.6N 114.7W
Posted: 01/10/19 10:50am Link  |  Quote  |  Print  |  Notify Moderator
I like the term "caster authority". Having the experience of going from +3.5 degrees to +5.5 degrees caster even though at the same weight, I still think I know the feeling.
DutchmenSport
Over There
Posted: 01/10/19 10:56am Link  |  Quote  |  Print  |  Notify Moderator
Delete
* This post was edited 01/20/19 07:56pm by DutchmenSport *
ArchHoagland
Clovis, CA, USA
Posted: 01/10/19 11:15am Link  |  Quote  |  Print  |  Notify Moderator
DutchmenSport wrote:
"40' Diesel Pusher wandering on the road" ????
Did it ever find it's way home? [emoticon]
Some who wander are not lost.
2004 Monaco La Palma 36DBD
Workhorse W22 8.1 Gas Allison 1000, 7.1 mpg
US Gear Brakes
maddog348
Bakersfield,CA
Posted: 01/10/19 11:16am Link  |  Quote  |  Print  |  Notify Moderator
Bad Dutch, Bad ~~ Ya beat me to it.
janstey58
Glenwood, IA
Posted: 01/10/19 11:20am Link  |  Quote  |  Print  |  Notify Moderator
Don't these guys take the potential new units for a long test drive??
Jeff and Kim
2015 Fleetwood Discovery 40E
Freightliner Chassis 380HP DP
2012 Ford Escape Limited Toad
Acampingwewillgo
Posted: 01/10/19 01:25pm Link  |  Quote  |  Print  |  Notify Moderator
Not sure how popular they are nowadays, but certainly Steering stabilizers use to be recommended. I happen to have one that as far as I know, is not made any longer, "Howard Power Center Steering Stabilizer". Presumably one of the better ones ever made. Long story short, it works very well in holding you on the road with little effort. No cross wind problems, no Truck passing issues and minimal steering effort.
As I recall Blue Ox made a similar product and other manufacturers such as Steer Safe had some too.
As related previously, there are plenty of approaches available to correct such an issue...
96 Vogue Prima Vista
The Kid's: Humphrie, the Mini Schnauzer and Georgie,wire haired dachshund, Senior Cavalier Rosie and Potter
Rainbow Bridge: Laddie,Scoutie,Katie,Cooper,Kodie,Rubie,Maggie, Cassie and Mollie, Elvis Love You!
Rally's and get togethers-Lots
Ivylog
Blairsville, GA and WPB, FL.
Posted: 01/10/19 04:34pm Link  |  Quote  |  Print  |  Notify Moderator
Often it’s the nut behind the steering wheel that needs tightening. My “new” ride had a steering stabilizer on it and I found it made driving tiring where my previous rig (same chassis) did not. It wanted to center the steering even though with a cross wind the steering needed to be off center. It also made turning the steering wheel harder so I disconnected it which got it back to what I was used to. I recently needed the steering wheel turned 45 degrees to go straight...was glad I didn’t have to fight the stabilizer too. I may make a air operated slip connection so the centering can be moved from center and reconnect it.
I would not add a stabilizer unless it is adjustable.
08 HR Navigator 45'
Sold 04 Dynasty after 14 great years.
How I tow.
Towing a Prius without a dolly
How I spend the winter.
