RV.Net Open Roads Forum: Class A Motorhomes: Just venting....
 > Just venting....
Wherever I happen to park
Posted: 01/10/19 08:00am Link  |  Quote  |  Print  |  Notify Moderator
there are. in fact. several solutions to that problem
one is a cord winder. another This is a device patterened after a pitching machine or tennis ball machine used for batting/tennis practice. Only instead of spitting out balls it pulls in the cord which then coils in a TUB much like what many above show.
A Cord REEL like a hose reel (I do not care for these)
There is a type of cord I call a "Super flex" it has a different (Plastic I think) jacket instead of the one that gets real stiff in cold weather. Also the strands of wire are both thinner and more (more strands thinner) so it flexes very easily.. I have a 30 amp cord for my Rig (Currently in use) made of that stuff. Coils as easly at 20 degrees as at 80.
Check with your RV supplier for ready made "Super flex" cold weather cords.
This is an example at home Depot
Also a shorter cord (The one above is 15 feet) makes it easier to wrangle but you may need an extension cord with a short cord. Those alos come in assorted lengths.. I googled "Cold weather 50 amp rv power cord" by the way.
Home is where I park it.
rk911
Wheaton IL
Posted: 01/10/19 08:47am Link  |  Quote  |  Print  |  Notify Moderator
way2roll wrote:
Have you considered an electric cord reel?
that’s precisely what we did. 25’ on an electric reel. no muss, no fuss. i carry an additional 25’ feet just in case but in 3- yrs have only had to use it once.
'73,
rich, n9dko
Every retired man needs three things....a good truck, a good dog and a working wife
2016 Itasca Suncruiser 38Q
'46 Willys CJ2A
'03 Jeep Wrangler TJ
'10 Jeep Liberty KK
goufgators
Crawfordville, Florida
Posted: 01/10/19 12:30pm Link  |  Quote  |  Print  |  Notify Moderator
Ivylog wrote:
Buy a 50 to 30 adapter and a 30amp cord...back to the good old days and problem solved.
Such a simple but workable solution! Thanks for the reply...
2017 Winnebago Sunstar (gas)
2005 Honda CRV Toad
Invisi-brake
Posted: 01/10/19 04:41pm Link  |  Quote  |  Print  |  Notify Moderator
Oh what I do... Right now my 50 amp cord is in a Rip-Stop Nylon bag in my car.
On a 50 amp back in site I pull up. Unhook pull the car in and toss the bag out at the power pole.. Then pull out park the car back the MH in and hook up
Exiting I reverse that process Way easier to stow it in the car than the RV.
30 amp site it stays in the bag in teh car and I break out the 30 anp cold weather Superflex cord. Which I am using now.
Walaby
Georgia
Posted: 01/10/19 06:32pm Link  |  Quote  |  Print  |  Notify Moderator
Wouldn't drawing 50 amps over a 30 amp cord potentially over tax the 30 amp cord?
Mike
Im Mike Willoughby, and I approve this message.
2017 Ram 3500 CTD (aka FRAM)
2016 Lacrosse 324RST
rhagfo
Portland, OR
Posted: 01/10/19 06:49pm Link  |  Quote  |  Print  |  Notify Moderator
Mike
You are correct, the use of a 50 to 30 amp adapter, to use a 30 amp cable to feed a 50 amp panel is a very bad solution. You could be potentially drawing 50 amps over a 10 gauge cable. P[emoticon]
Best solution is using SOOW 6/4 cable! Soft supple and will carry the load!!!!
2016 Ram 3500 DRW Laramie
2001 Dodge 2500 4X4, 5.9 Cummins, NV4500, 3.55's, Pacbrake PRXB, DS Power Puck,RV 275's Bilstein 5100's, 313K miles.
rk911
Wheaton IL
Posted: 01/10/19 07:03pm Link  |  Quote  |  Print  |  Notify Moderator
if a 30-amp adapter is placed on a 50-amp cable that cable can only be connected to a 30-amp source. on our coach the EMS (energy mgmt system) senses that and won't allow more than 30-amps (actually 80% of 30-amps) to be drawn. the last two coaches we've had since 2000 had that. in the op's situation the 50-30 adapter plugs into the 50-amp connector on the RV and the 30-amp cord into that.
Walaby
Georgia
Posted: 01/10/19 07:15pm Link  |  Quote  |  Print  |  Notify Moderator
And in that case, the 30 amp cable will potentially draw 50 Amps, unless you plug into the 30 amp outlet at the source.
OP wants the convenience of 50 amp without the bulk of the traditional 50 amp cable. The alternative cable source is the best option.
Mike
rk911
Wheaton IL
Posted: 01/10/19 07:39pm Link  |  Quote  |  Print  |  Notify Moderator
Mike
a 30-amp cable can only plug into a 30-amp source. i may not have been clear.
the OP is looking to go back to the good ole days of 30-amp RVing cuz the 30-amp cord is easier to handle. the only safe way to do that, IMO, is to use a 50-30 amp adapter at the RV end to which a 30-amp cord is connected between the RV and the 30-amp connection at the post. this presumes the OP's RV has a smart EMS which detects the 30-amp connection. this also presumes that his 50-amp cord is not permanently attached to the RV but rather must be plugged into the RV and the post.
me? i think the bucket idea or the electric reel is the way to go.
Walaby
Georgia
Posted: 01/10/19 08:16pm Link  |  Quote  |  Print  |  Notify Moderator
I was thinking you meant 30 to 50 amp connector on trailer end AND 50amp to 30 amp connector on the source end, using a 30 amp cord in the middle, thereby theoretically accessing 50 AMP, over a 30 AMP cord.
I like the SOOW 6/4 cable idea. Im seriously considering that option myself.
Mike
 > Just venting....
