RV.Net Open Roads Forum: Class A Motorhomes: SAFETY WARNING FOR TOADS
 > SAFETY WARNING FOR TOADS
Page of 8
wildmanbaker
Kennewick, Washington
Posted: 01/11/19 11:58am Link  |  Quote  |  Print  |  Notify Moderator
Well, we seem to be getting information as people post things that may have been related to the failure, second-hand at that. If this is indeed a Thor problem, NTSB needs to informed of it.
Wildmanbaker
4x4van
California
Posted: 01/11/19 12:21pm Link  |  Quote  |  Print  |  Notify Moderator
I'd like to see a picture of the actual hitch that is being used; the drop specifically. I'd also like to see the same from the previous owner. It's quite possible that the previous owner, since they only towed a small trailer, was using a significant drop hitch; class A's typically have a fairly high rear bumper/hitch receiver, requiring a drop hitch, especially for a small trailer. That may have been in place and the PO backed into something (could have even occurred without the PO even knowing). The leverage that rgatijnet talked about can easily put much more force on that area than the actual weight. In any case, the damage has obviously been there awhile (the rust), although it may have just recently "opened up" so that the current owner noticed.
We don't stop playing because we grow old...We grow old because we stop playing!
2004 Itasca Sunrise M-30W
Carson enclosed ATV Trailer
-'85 ATC250R (2), '85 BW200, '07 TRX400EX, '12 Husky TE310
Zieman Jetski Trailer
-'96 GTi, '96 Waveblaster II, '95 FX1
irishtom29
San Antonio
Posted: 01/11/19 05:00pm Link  |  Quote  |  Print  |  Notify Moderator
aksnowman wrote:
Also the triangles (widgets) welded on the frame are additions that add strength that aren't on my brother's.
Those are called gussets.
stevenal
Newport, OR, USA
Posted: 01/11/19 05:37pm Link  |  Quote  |  Print  |  Notify Moderator
Report form
Please get your brother to report this. Maybe it will initiate a recall that might save a life or two. When the government re-opens, that is.
'18 Bigfoot 1500
Torklifts and Fastguns
'17 F350 Powerstroke Supercab SRW LB 4X4
aksnowman
Eagle River Alaska
Posted: 01/11/19 06:18pm Link  |  Quote  |  Print  |  Notify Moderator
stevenal wrote:
Report form
He has calls into the manufactures and we are gathering all the info to contact the NTSB.
AK Snowman
Eagle River AK
aksnowman
Eagle River Alaska
Thanks..
Dale.Traveling
Newport News, VA
Posted: 01/12/19 04:28am Link  |  Quote  |  Print  |  Notify Moderator
aksnowman wrote:
The mounting of the hitch with the plate on top of the frame sure looks better than what is on my brother's. Also the triangles (widgets) welded on the frame are additions that add strength that aren't on my brother's.
Question, are you using and extensions at the hitch or a riser to move the hitch up and down?
I did when I was towing an Accord to reduce bar angle and to add a bike rack to the setup (didn't want to add a rack to the Accord). When I changed to a CR-V the drop coupler wasn't needed and the CR-V had a hitch receiver for the bike rack.
2006 Hurricane 31D built on a 2006 Ford F53
Dale.Traveling
Newport News, VA
Posted: 01/12/19 05:11am Link  |  Quote  |  Print  |  Notify Moderator
wildmanbaker wrote:
I really can't tell from the picture, the near side looks like the ford frame rail, but the inside of the far rail looks different. Most of the manufactures extensions look like Dales pictures, square edges at the bends, not roll formed. Most manufactures extensions are really a cobbled-up mess of steel with some ugly welding.
My hitch is on extensions and it would be a rare (not saying there are none) Ford chassis that didn't have extensions once a builder gets done with it. All F53 chassis are delivered with same rear overhang of 105.8 inches from rear axle center to the end of the frame.
Looking at the pic of the failure it is apparent that the hitch is attached to house builder added extensions. You can see the Ford frame on the right side of the edge near the fuel tank. Also in view is the last frame cross member. Of note is the frame section height is 9.2" at this point. If you follow the rail to where it disappears behind the hitch (Blue Line), when it reappears the lower edge (red line) of the rail is now several inches closer to the floor of the coach. Also you can see how the extension is bend on the far edge of the hitch (yellow line).
wildmanbaker
Posted: 01/12/19 03:25pm Link  |  Quote  |  Print  |  Notify Moderator
Dale, I believe you are correct. I just came in from sliding under our MH and measured the frame from the last cross member, and it is 18". Your other measurements are the same as our frame, except, ours is a Fleetwood and has the raised rail construction, which has 10" on top of the Ford frame rails. The rolled corners really had me fooled about it being the actual ford frame. I believe they should not wait for the manufacture to act, NTSB should be contacted quickly.
roam1
Gulf Breeze FL
Posted: 01/12/19 04:30pm Link  |  Quote  |  Print  |  Notify Moderator
looks to me the failure was casued by excessive torque where the hitch is bolted to the frame. This torque could come from overloading the hitch weight or from a sudden stop while towing with a drop down hitch. Say the toad brakes were not adjusted properly and you have a 5000# toad pushing on even a slightly dropped hitch ball, that can produce a heck of a lot of torque at the hitch mount point and easily exceed the torque max spec determined by weight and distance. Even though everyone thinks they don't overload their hitch, I bet they do occasionally.
Page of 8
