RV.Net Open Roads Forum: First look at travel trailers today at Camping World
 > First look at travel trailers today at Camping World
breeves2245
Northwest Arkansas
Posted: 01/10/19 01:16pm Link  |  Quote  |  Print  |  Notify Moderator
I did look at Bigfoot and Oliver. That is a completely different price range. If this was my second purchase and I felt real sure about what I wanted, I would not be hesitant to upgrade. I watched some YouTube production videos, both impressive.
Whatever I get, I want to be able to sell without too much of a hit. One more reason to lean toward the fiberglass rv's.
DutchmenSport
Between Anderson, Pendleton, & Lapel, Indiana
Posted: 01/10/19 01:39pm Link  |  Quote  |  Print  |  Notify Moderator
The longer they are, the easier they tow and the easier they are to back up. The shorter they are, the more challenging it gets because the reaction time is so fast you often jack-knife a trailer and don't even realize it. Reaction time on longer trailers give you time to react, but also requires a little more space to back up, turn, etc.
Duel axles create a more stable ride. With duel axles, when backing, one tire is usually the pivot tire and the other one will often skid sideways some. Depending on the angle of the back-up, skidding may be non-mute or it could be severe. Either way, it's just the nature of duel's. I prefer duel's.
I won't comment on Camping World since they are the sponsors of these forums, but I do encourage you shop around before you settle.
The advantage of the smaller trailers is the fact you can park them almost anywhere. The draw back is, they seem to get claustrophobic real fast if you spend any time in them.
The one real positive note about any of them.... it sure is more comfortable than using a tent on the ground!
DutchmenSport
2019 Montana High Country 375FL Fifth Wheel
2014 Chevy Silverado 3500 Duramax Dually
2 dachshunds, 1 cat, 2 old folks, lots of love.
And yes, it really does have a door on the opposite side:
jerem0621
Tennessee
Posted: 01/10/19 02:02pm Link  |  Quote  |  Print  |  Notify Moderator
Add 5 ft as a start.
It is crazy how small our 31 ft TT felt after three days of rain.
Towing a small trailer is slightly more nimble in a gas station but it’s not unbearable by any means to tow a larger one. You get use to the size pretty quick.
Remember when towing in tight spaces it’s all about the set up. Take up as much room as you need and think about your exits.
Regardless of the trailer you choose figure 8 mpg while towing to estimate your gas stops and then look on Google Maps at the satellite view along your planned route. Find gas stations that look like they will accommodate your rig.
Typically the Flying J, Pilots, and some T/A’s work great for TT’s. (Not the T/A or Loves south of Atlanta ... those two are ROUGH for trailers... IMHO.
But seriously, look at the largest trailer you envision for your use. Just know that for most of us, it’s about 5 ft too short on our first trailer.
Camping Worlds vary... some are great some are not. It depends on the people running the store.
JMHO based on experience.
Thanks!
Jeremiah
SoundGuy
S Ontario
Posted: 01/10/19 02:26pm Link  |  Quote  |  Print  |  Notify Moderator
breeves2245 wrote:
I have the 5.3 with 3.73 rear end. So no issue.
Yeah, same thing all newbies say. [emoticon] Believe it, you won't want to be towing any more than 6000 lbs fully loaded with your Silvy, less would be even better. Our 19' Freedom Express typically averages 4500 - 4800 lbs loaded & ready to camp and I can sure tell I'm dragging nearly 2.5 tons behind me with my Silvy. [emoticon]
2014 Coachmen Freedom Express 192RBS * 2003 Fleetwood Yuma
2008 K-Z Spree 240BH-LX * 2007 TrailCruiser C21RBH
2000 Fleetwood Santa Fe * 1998 Jayco 10UD * 1969 Coleman CT380
Death Valley!
Posted: 01/10/19 02:35pm Link  |  Quote  |  Print  |  Notify Moderator
"and 1,000 tongue weight."
SoundGuy is right. My Tahoe is rated to "pull" 8,500 pounds but 6,000 is a resonable limit. I'm 5,200 wet and loaded. You haven't discussed your truck's PAYLOAD...not the same as bumper weight limit.
2015 Winnebago 2101DS TT & Tahoe LTZ, 300 watts WindyNation solar-parallel & MPPT, Trojan T-125s. TALL flagpole for US flag. Prefer USFS, COE, BLM, NPS, TVA, USF&WS, state & county camps. Bicyclist! 14 year Army vet - 11B40 then 11A - old MOS 1542 & 1560.
ken56
Tennessee
Posted: 01/10/19 04:22pm Link  |  Quote  |  Print  |  Notify Moderator
I towed my 30ft. 6500lb Coleman with a 1500 Silverado 5.3, 3:73 rear end with absolutely no problem, even in mountains. I had no issue in gas stations for the most part although you do need to be able to size one up pretty quickly if you can get in and out. If its just you then 22-24 ft. would give you space for some comfort. I can't imagine being tucked into an Rpod for rainy days, not that I would melt from getting wet. Rain is only somewhat of a deterrent to some folks. Don't be too hasty to buy one. As others said, look for a lightly used unit. They are out there.
rexlion
Broken Arrow OK
Posted: 01/10/19 08:17pm Link  |  Quote  |  Print  |  Notify Moderator
If you had a short wheelbase vehicle, I'd say get the short trailer for sure. But with that pickup, it's not much of an issue.
I started with a popup, for just one summer. Didn't like it. Then a 23' Rockwood, nice but had to sell (2007) due to wife's med bills. She won't camp any more, so since then I've had a 17' Burro, then a 16' KZ, then a little Aliner. Now I'm camping out of my Li'l Hauley cargo trailer (an empty Snoozy shell). The Burro and Hauley tow noticeably easier (a couple mpg's higher) than the boxy trailers; they are more rounded, more narrow, and shorter so the wind resistance is less. Wind resistance will matter more than weight to a great degree for highway-speed towing.
I would recommend a TT that allows a full time bed (so you don't have to make it daily) and a comfortable place to sit (those upright dinette seats are the pits after a couple hours). A front bunk, side bath Scamp 16 would work; you can leave the dinette made up as the bed all the time, have the front set up as a 'sofa' and use a tv tray type of table for eating up front. The back cushion is canted so it's more comfortable. If you buy a boxy TT, I'd say try to keep the width at 7' or max 7.5'. Oh, and no slideout. JMO.
BTW, that KZ I owned for 3.5 years and it developed a roof leak shortly after I sold it. I felt bad for the new owner and went halfway with him on a re-seal.
Mike G.
--for now, using a cargo trailer for camping--
To every thing there is a season, and a time to every purpose under the heaven... (Ecclesiastes 3)
Yosemite Valley view from Taft Point
scbwr
North Ridgeville, OH
Posted: 01/11/19 05:47am Link  |  Quote  |  Print  |  Notify Moderator
I'll second the motion that if it's your first trailer, buy used and after a year or two of using it, you will have a better idea of what will be your ideal trailer. And, by buying used, you shouldn't take to much of a hit when you sell it.
In terms of smaller trailers, I suggest you check out the Winnebago line of trailers. They are better than entry level and they have a wide range of size and weight ratings. We had a 2014 Minnie 2201DS trailer and it was well made and we only had a couple of things that had to be done under warranty. If you want a 4 season trailer, look for used Arctic Fox but be aware that they tend to be heavier due to their construction, but are great for cold weather camping.
I can see why you would want a Casita or Oliver trailer. But after having some experience, you'll be in a better position to know what size will work for you and what amenities are important to you.
If you plan to camp without hookups, you will want to compare tank capacities and the ability to easily increase the number of batteries and/or solar panels for keeping them charged.
Good luck in your search!
2012 Newmar Bay Star 3302
Blue Ox Avail
BrakeBuddy Advantage
2015 Malibu
"Get busy living, or get busy dying."
Andy Dufresne, The Shawshank Redemption
drsteve
Michigan
Posted: 01/11/19 06:35am Link  |  Quote  |  Print  |  Notify Moderator
The nice thing about buying a used Casita or Scamp is that these fiberglass eggs hold their value much better than conventional construction. You can buy one, use it for a season or two, and sell it for close to what you paid.
1991 Palomino Filly PUP
GrandpaKip
Flat Rock
Posted: 01/11/19 07:31am Link  |  Quote  |  Print  |  Notify Moderator
If I were to go solo, I definitely would look at one of the eggs. I would also want a permanent bed and a bathroom.
A lot depends on your style of glamping. I tend to use the camper as a place to sleep and store my stuff. Others gotta have a large tv, DVD player, fireplace, recliners, etc. The majority are somewhere in between.
Enjoy the search.
Kip
2015 Skyline Dart 214RB
2018 Silverado Double Cab 4x4
Andersen Hitch
