RV.Net Open Roads Forum: Tech Issues: Leveling with half of a Lynx block??
 > Leveling with half of a Lynx block??
Page of 6
profdant139
Posted: 01/10/19 06:57pm Link  |  Quote  |  Print  |  Notify Moderator
We use those Lynx blocks (they look like giant Legos) to level our trailer. Works well, does not slip, easy to store and to clean.
But every so often, a stack two blocks high is not enough, while three blocks are too many.
Has anyone developed a halfway step? I tried to make one out of wood and it did not work well -- it tended to slip out of place as I drove the trailer up onto the stack of blocks.
Thanks in advance for your ideas and advice!
Our trips -- pix and text
About our trailer
"A journey of a thousand miles begins with a single list."
jkwilson
Indiana
Posted: 01/10/19 07:07pm Link  |  Quote  |  Print  |  Notify Moderator
I use plywood with a thin sheet of rubber stapled on.
John & Kathy
2014 Grand Design Reflection 303RLS
2014 F250 SBCC 6.2L 3.73
Crestview area, Inyo County, California
Posted: 01/10/19 07:08pm Link  |  Quote  |  Print  |  Notify Moderator
In dirt or sand I use my shovel.
2015 Winnebago 2101DS TT & Tahoe LTZ, 300 watts WindyNation solar-parallel & MPPT, Trojan T-125s. TALL flagpole for US flag. Prefer USFS, COE, BLM, NPS, TVA, USF&WS, state & county camps. Bicyclist! 14 year Army vet - 11B40 then 11A - old MOS 1542 & 1560.
RCMAN46
NorthWest
Posted: 01/10/19 07:21pm Link  |  Quote  |  Print  |  Notify Moderator
I have a set of these which should solve your problem.
1/2 inch leveler
* This post was edited 01/11/19 08:42am by RCMAN46 *
DrewE
Vermont
Posted: 01/10/19 08:23pm Link  |  Quote  |  Print  |  Notify Moderator
1/2 a block out of level isn't going to harm anything, though if you find it annoying I guess that's something.
With a motorhome, all I have to do is add one to only one wheel position rather than two in order to get half a step. If you have dual axles on the trailer, maybe something similar would work, adding a block to only one of the two axles on a side. The suspension takes up the unevenness.
SteveAE
Bend, Oregon
Posted: 01/11/19 01:27am Link  |  Quote  |  Print  |  Notify Moderator
I switched to the Andersen Camper Leveler awhile back and am very pleased for all but extreme leveling situations. I put a big level on the front of my trailer and simply watch it as I pull onto the levelers. Way faster than the lego style blocks or boards. The only situation I have had difficulties using this product on is slick surfaces (which I seldom camp on anyway), where the levelers sometimes slip. A piece of rubber mat under each leveler solves this. Now I just use the lego blocks under my stabilizers.
rockhillmanor
On the Road
Posted: 01/11/19 05:58am Link  |  Quote  |  Print  |  Notify Moderator
Go with the 3 blocks that you feel are a little bit too high.
Dig into the ground where you place these blocks until you get the height you need. Sometimes just a little scraping of the ground is all it needs.
We must be willing to get rid of the life we've planned,
so as to have the life that is waiting for us.
drsteve
Michigan
Posted: 01/11/19 06:47am Link  |  Quote  |  Print  |  Notify Moderator
If you're worried about the fridge, don't be. Half a block won't matter.
1991 Palomino Filly PUP
prichardson
Lafayette, La
Posted: 01/11/19 07:40am Link  |  Quote  |  Print  |  Notify Moderator
1/2 Lynx block off will not hurt anything. If you have tandem axles putting a block under just one will achieve a 1/2 block adjustment.
mbopp
Henrietta, NY, USA
Posted: 01/11/19 07:46am Link  |  Quote  |  Print  |  Notify Moderator
I use 2X6's cut, beveled, & stackable. And I'll use one block of I need some fine tuning, it doesn't hurt anything.
2017 Grand Design Imagine 2650RK
2012 F-150 XLT Ecoboost ("EcoBeast") supercab
Just DW & me......
Page of 6
