RV.Net Open Roads Forum: Tech Issues: Leveling with half of a Lynx block??
 > Leveling with half of a Lynx block??
Page of 6
ppine
Northern Nevada
Posted: 01/11/19 07:55am Link  |  Quote  |  Print  |  Notify Moderator
You are not building a house that has to be plumb and square, you just need for your frig to work right.
SoundGuy
S Ontario
Posted: 01/11/19 08:26am Link  |  Quote  |  Print  |  Notify Moderator
I've been using one variation or another of my DIY Lynx/Wood leveling system for years with a number of different trailers and can fine tune side-to-side level within 3/4". I have 2 folding bases, one with a base layer of Lynx mounted to the base and a second base with no Lynx mounted to it. Should I level and find I'd still like to lift the trailer's low side a bit more but less than a full Lynx I can place the high side non-Lynx base under the Lynx base. Works like charm, level is just about perfect every time. [emoticon]
More pics are in my Gallery.
2014 Coachmen Freedom Express 192RBS * 2003 Fleetwood Yuma
2008 K-Z Spree 240BH-LX * 2007 TrailCruiser C21RBH
2000 Fleetwood Santa Fe * 1998 Jayco 10UD * 1969 Coleman CT380
Boomerweps
Hills of PA
Posted: 01/11/19 08:44am Link  |  Quote  |  Print  |  Notify Moderator
The Lynx cap blocks will gain you a little from the tire not pushing into the block tops.
Sometimes you have to accept tolerances. Perfect is the enemy of good enough.
The cap blocks are also great when you only want a single layer and can link it together to stop them from sliding apart.
2019 Wolf Pup 16 BHS Limited
2008 Ford Exploder 4.0L
Boomerweps
Hills of PA
Posted: 01/11/19 08:47am Link  |  Quote  |  Print  |  Notify Moderator
SoundGuy wrote:
[image].
Where did you find the Lynx half width blocks? What is their proper name for a search?
* This post was edited 01/11/19 10:16am by Boomerweps *
camperdave
northern, California
Posted: 01/11/19 09:03am Link  |  Quote  |  Print  |  Notify Moderator
To those saying it doesn't matter, and within a block is good enough, you just don't get it. [emoticon]
I'm one of those level-sensitive types. I need to be very close, or I'm discombobulated all day long. I also get carsick easy, and get motion sick in movie theaters, it's probably all related...
Anyway, I used 2x10's on my old trailer, to get a 3/4" lift I'd put one under only one of the tandem wheels on one side.
That obviously doesn't work for you (as you're single axle), and it doesn't work for me anymore with the motorhome. So I now pack a few pieces of 3/4" plywood for the fine tuning.
I'm just wood on wood and have not had issues with slippage. Maybe to use plywood with your blocks you could add rubber to one side of the wood, then put the leveler legos on top of that?
2004 Fleetwood Tioga 29v
BarneyS
S.E. Lower Michigan
Posted: 01/11/19 09:22am Link  |  Quote  |  Print  |  Notify Moderator
Moved to Tech Issues forum from DIY.
profdant139
Posted: 01/11/19 09:23am Link  |  Quote  |  Print  |  Notify Moderator
Some great tips -- thanks! And yes, I should add that DW is very sensitive to un-level conditions. This is not about the fridge -- it is about her comfort, which (as you might imagine) is pretty important to me. [emoticon]
Our trips -- pix and text
About our trailer
"A journey of a thousand miles begins with a single list."
ependydad
Here and there
Posted: 01/11/19 10:41am Link  |  Quote  |  Print  |  Notify Moderator
prichardson wrote:
If you have tandem axles putting a block under just one will achieve a 1/2 block adjustment.
How has everyone missed this? This is the answer.
2017 Spartan 1245 by Prime Time
2012 Ram 3500 Crew Cab DRW w/ 4.10 gears and 8' bed
FW Hitch: B&W Turnover Ball + Companion
Learn to RV- learn about RVing - Towing Planner Calculators - Family Fulltiming FB page
camperdave
Posted: 01/11/19 10:54am Link  |  Quote  |  Print  |  Notify Moderator
So are you suggesting the OP add another axle to his trailer? [emoticon]
SoundGuy
S Ontario
Posted: 01/11/19 11:02am Link  |  Quote  |  Print  |  Notify Moderator
Lynx manufacturer doesn't offer half Lynx so I made my own, cutting them on my table saw.
Page of 6
